Port 2 speed limitation — need service moved to port 1 but blocked by incomplete BT cease
FIXED- Subscribe to RSS Feed
- Full Fibre
- Re: Port 2 speed limitation — need service moved t...
Re: Port 2 speed limitation — need service moved to port 1 but blocked by incomplete BT cease
2 weeks ago
Thread moved from Broadband to Full Fibre
2 weeks ago
Interesting, that shows the ONT is fine and so is the cable.
So just to confirm, using the same cable to connect the ONT back to the WAN port and the link speed shows back to 100Mb ?
If that's the case , then the Hub 2 is faulty.
2 weeks ago - last edited 2 weeks ago
@wohdivad wrote:
The ond is a Huawei Echo Life HG8240
That appears to be an ONT/router in its own right, intended for use in a business environment
https://manualmachine.com/huawei/echolifehg8240/
Should be able to connect to it via a browser and see what is going on - if you have password access, I presume.
"root" and "admin" seem to be the given defaults for User and Password.
I did note that about the ONT, however the OP does not have a wired ethernet port available.
Edit: See post 24.
2 weeks ago
Whilst the hardware might be capable , I suspect the Openreach implementation is locked down in functionality
2 weeks ago
2 weeks ago
2 weeks ago
2 weeks ago
And the WAN:
2 weeks ago
Yes, confirmed
@Dan_the_Van can you see any other possibility other than a Hub 2 WAN port fault ?
Maybe I'll drop Bob a PM for his throughts
2 weeks ago
I would look into the WAN socket to see if any of the pins are missing
There is no setting on this Hub to change port speeds.
It might be worth a Hub factory reset?!
2 weeks ago
Yes, worth a look with a magnifier to compare the pins on the WAN port with one of the LAN ports, checking for missing or bent pins
Worth a try if we havent already done that...
@wohdivad are you up for that ?
2 weeks ago
2 weeks ago
No change on reboot but, yes, the left pin of the WAN port looks faulty. How can I attach a picture to show you?
2 weeks ago
- Full Fibre
