Plusnet hub two flashing orange help
Antonz85
Hi guys im on fibre and i have a plusnet hub two modem i just got home an hour ago and noticed my modem is just flashing orange.
Ive tried to reset it.
Turnt plug off all the usual.
Is plusnet down?
7 REPLIES 7
Fixes: 479
Re: Plusnet hub two flashing orange help
@Antonz85   Welcome to the Plusnet Community Fora.
Report a fault using the mobile bot. See https://www.plus.net/help/report-a-problem/broadband/?_ga=2.56464873.311885833.1701254235-1638889408...
adamwalker
Fixes: 223
Hi @Antonz85
I've just checked your account and can see you've reported the issue.
Sorry for the disruption and we'll get that sorted out as soon as we can.
Adam
 Adam Walker
Antonz85
Is the line going through the socket working still. as i have no home phone to try landline wise.
Or is there any update?
adamwalker
Fixes: 223
I've just checked back and can see there's actually an MSO (major service outage) affecting your area.
Openreach are on the case and should have it resolved by tomorrow, sorry for the disruption in the meantime.
Adam
 Adam Walker
@Antonz85
You might be able to get details/progress of your local MSO by putting your phone number in to -
        https://status.zen.co.uk/broadband/
Antonz85
Thanks so much ill have a look!
Antonz85
Strange theres no issues or anything when i put my number
