Ping spikes
GetBeaned
Ping spikes
Hello, I just switched to Plusnet from Vodafone and now I'm getting ping spikes in games I play. It's most noticeable with the game Heroes of the Storm, where my ping will comfortably around 13ms and spike to 30ms once a minute or so, sometimes lasting up to three seconds which the game can even identify as a disconnect.
I didn't have this problem with Vodafone, and the only difference in hardware is the router itself, switching the Vodafone Wifi Hub to the Plusnet Hub Two. I have two Eero 6's connected in bridge mode, as I did with Vodefone.
Thanks.
2 REPLIES 2
GetBeaned
Re: Ping spikes
To follow on to this, I took the Hub Two out the equation completely and connected one of my Eero hubs as the primary router with PPPoE and I'm seeing the exact same issue.
markhawkin
Champion
Fixes: 22
Re: Ping spikes
All I can think of is differences in peering between Vodafone and Plusnet.
As I understand it, Vodafone peer in lots of locations, I have the impression that BT/Plusnet it's less distributed.
Why you are getting spikes in ping I don't know.
Assuming the Eero is able to respond to a WAN ping, setting up a ThinkBroadband monitor
https://www.thinkbroadband.com/broadband/monitoring/quality
would provide further data.
If you connect over WiFi, that would be my first thought but I can't see why the WiFi performance would be different between Vodafone & Plusnet using the same Eero setup.
