Openreach wanting to cut our copper phone line
- Full Fibre
- Openreach wanting to cut our copper phone line
27-12-2025 5:09 PM
Re: Openreach wanting to cut our copper phone line
28-12-2025 11:00 AM
You must have a work mobile / hotspot as a Plan B for the using the internet for WFH.
What is Openreach plan in the event it is not possible to use the phone line to pull a fibre connection into the blocked duct ?
28-12-2025 11:43 AM
This gives much aggro but moving to another ISP won't help -- all are beholden to Openreach, and we peasants are not allowed to speak direct to OR. I suggest you use your wife's vulnerable person status and phone PN again. The copper network is due for closure in near future so you will have to have new arrangements in place.
As others suggest you should have mobile backup ready, perhaps your wife's employer will fund a modem for her BB use.? Be prepared for further delays if the duct needs excavation to clear it. You never know what's down there until you dig -- speaking as an expert digger driver who can find the water main with his first bucket or two 🙄
28-12-2025 9:12 PM
If you depend on the Internet connection for working at home, personally I would order the full fibre as an ADDITIONAL service and (for a while at least) keep both going. You could then cancel the copper connection at a later stage.
This may be tricky to do and may involve cancelling the current Plusnet order (and may require an order on a supplier who can cope with the concept of an additional connection instead of Plusnet) but would probably be safer.
If any mobile network has decent coverage where you are, I would also go down the mobile hotspot route as well.
- Full Fibre
