ONT Power over the Ethernet
FIXED- Subscribe to RSS Feed
- Full Fibre
- ONT Power over the Ethernet
yesterday
Fixed! Go to the fix.
Re: ONT Power over the Ethernet
yesterday
You need to talk to the installer on the day, they will run up to 10m of fibre from the outside CSP to the ONT provoding that it doesn't require passing through internal walls.
As an aside, I have successfully powered an ONT over the Ethernet WAN cable using a TP-Link TL-POE150S Injector and POE 10R splitter. If there isn't a convenient mains socket, you could always present the installer with a mains extension lead to allow them to check out the installation using the official power supply.
yesterday
Have a look at the following.
https://www.openreach.com/help-and-support/full-fibre-broadband-installation-checklist
The video isn't quite accurate in so much as the router is connected via ethernet so can go anywhere you're happy to run cable. It doesn't need to be near the ONT.
There is a certain leeway as to where the external CSP and the internal ONT is situated - you speak to the installer on the day to see what's possible aginst the desirable.
yesterday
- Full Fibre
