Not getting speed
danyuri86
Not getting speed
Is there something going on with the network atm.... just got the 145 down/30 up package. Was working great for the 2 days since had it but today I checked and
https://www.speedtest.net/result/19660161997
nothing changed on my end...
2 REPLIES 2
Re: Not getting speed
@danyuri86
Are you checking with a wired device, for WiFi you need to check which band your testing device is connected, 2.4GHz band will give a slower connection speed.
danyuri86
good shout. I went to 192.168.1.254 and disable 2.4 to force my pc to use 5gz and now I'm getting full speed again, cheers
