No speed increase with upgrade.
Eggs
Re: No speed increase with upgrade.
I look forward to trying it Bob.
Eggs
I have just done a speed test and have the following results:
513.8/68.5 on my wired PC,
and 455/71.3 on my iphone11 (wireless).
This all on my original system.
bobpullen
Fixes: 329
@Eggs - we're getting somewhere then Smiley
I'm going to try moving you back to the provisioned product you're paying for later today, so keep an eye on things tomorrow and let me know how you get on.
Eggs
Fingers crossed.
Eggs
@bobpullen @Townman @bill888
An interesting strategy to cure an Openreach fault without involving Openreach.
Download speed on my wired PC: 303.7 Mbps
Upload speed on my wired PC: 46.0 Mbps
Download speed on my iPhone 11: 309 Mbps
Upload speed on my iPhone 11: 47.9 Mbps
My Plusnet Broadband Service:
  • Product:  Full Fibre 300
  • Estimated Download Range:  300 - 330Mbps
  • Estimated Upload Range:  45 - 50Mbps
  • Minimum Guaranteed Speed:  165Mbps
  • Current Line Speed (Download):  330Mbps
  • Cost £29.99 a month
bobpullen
Fixes: 329
@Eggs - perfect, thanks for letting me know - and apologies for the hassle!
Eggs
One month after my issue was resolved, I can now confirm I am very satisfied with the service I am receiving.
My internet connection is constant, flawless and fast:
PC wired download: 304.1 Mbps
PC wired upload: 45.9 Mbps
iPhone 11 wireless download: 307.53 Mps
Cost: £29.99 a month
Rambo23
Hi @bobpullen
By any chance would you be able to try this solution for my account too please. I’m facing the exact same issue as the customer on this thread having upgraded from the exact same package of 145mb to the fibre 300 package also with all of the same issues as them.
The plusnet team have advised me to ask you if you’d be able to implement the same fix by replying on this thread.
Kind regards
bobpullen
Fixes: 329
@Rambo23 - that's exactly what I did here and it had no effect at your end other than to increase your upload (suggesting the regrade was successful in that regard). I don't expect different results from attempting the exact same thing again, so persisting down the fault route is my only suggestion if you are absolutely confident the issue isn't within your domain.
Rambo23
Thanks @bobpullen. Quick question. Would using a TP Link wifi extender cap the speed?
I have the wifi connection available for the router, and 2 wifi connections from the TP LINK (one is 2.5ghz the other one is 5ghz).
I’ve only tested the main router speeds with wireless and wired. Just wondered if the TP LINK could be capping the speed to the old speed of 145mb somehow?
Thanks again for any advice you can offer.
Fixes: 240
WiFi extenders will certainly use some of the WiFi band width impacting WiFi connection speeds, but that should not impact wired speeds. For the avoidance of doubt, when the device was Ethernet connected, was the WiFi turned off? Just because there’s a wire connected, if the WiFi is still turned on, there can be no certainty that the traffic is going over Ethernet.
bobpullen
Fixes: 329
According to this post, a direct PPP connection was made from a computer direct to the Openreach ONT i.e. bypassing all routers/extenders, and the speeds still didn't improve.
Is this still the case?
Edit: almost no way you're getting above ~145mbps from the 2.4GHz TP-Link access point.
