No internet today
Dangerjohn
No internet today
Total lack of broadband. It’s been drooping out every now and then recently but dead today.
not sure if my router is dead. Wireless still actually works8D66447C-BD45-44AC-A3FC-E186AAB005C7.jpegF459C5EB-58A4-45ED-8D47-1A6DCCAD2D00.png61E78296-AF04-4D18-AADA-7C7D8D5FDFD6.png
33 REPLIES 33
Fixes: 384
Re: No internet today
@Dangerjohn Those two reports indicate that you certainly have a problem somewhere - I notice your BTW report indicates you have a 'bridge tap' - usually caused by a problem with internal wiring, more on that later.
Your line is not the best, as the attainable speeds show, but you do have the option of FTTP, which would solve the problem, but would mean leaving PN as they don't have an FTTP product available, and are very reluctant to say when it might be available.
As an intermediate remedy, can you plug the Hub into your Test socket behind the faceplate on your main phone socket via a filter.
Before doing that though, please post your Hubs Help Desk page.
Dangerjohn
Hi, I won't be able to do the Test socket thing until tomorrow morning.
Also, I don't have a Hub. I have a different router. Would there be an equivalent page?
Fixes: 384
OK. Which modem/router do you have? Do you have the PN Hub hiding anywhere, as that gives readable data, which a large number of other equipment doesn't.
No problem with the test socket - the data I would like is that from your current situation - i.e. from a standard configuration.
adam945
Fixes: 113
Good morning @Dangerjohn
Thanks a lot for getting in touch on our Community Forums and I'm sorry to hear that you're having problems with your broadband service. I've checked the line this morning and can confirm that it's being affected by a Major Service Outage in the local area - Incident ID: IMT94923/21
Openreach are aware of it and will be working to get it resolved as soon as possible. At the moment though, the estimated resolution time / date is 10/12/2021. This might change, and the issue might be resolved sooner, though that's the only information we have at the moment.
Please accept our apologies for the frustration caused by this.
 Adam
 Plusnet Help Team - Leeds
Dangerjohn
Ok.thank you
Dangerjohn
Thanks for your help. I know it's definitely a problem outside now.
adam945
Fixes: 113
No problem at all, give us a shout if you need anything else in the meantime. Smiley
 Adam
Dangerjohn
Any update? I now have a DSL synchronised light on my modem but no Internet.
Fixes: 384
What does your modem/router report - If you tell us which it is, maybe we can aim you in the direction of the details we need ?
adam945
Fixes: 113
The MSO is still live on our end unfortunately, so it wouldn't surprise me if you're still unable to establish a working connection. Nevertheless,. if you're seeing the blue light on your router, it might be worth accessing your Plusnet Hub One Manager to see whether you're logged in with the correct credentials. Smiley
 Adam
Fixes: 384
@adam945 The OP is not using the Hub, but neither has he said what he is using.
adam945
Fixes: 113
Oh yeah, sorry about that! I remember reading that yesterday.
I've just checked again when this post came back through, still no updates on the MSO and the same ERT of 10/12/2021 is on the open incident. Sad
 Adam
Dangerjohn
Hi, sorry for lack of response.
I have an Archer Vr2800. All credentials are correct.
I have found out from local FB groups that lots of people in my neighbourhood have no Internet from various ISPs. (Sky and EE)
Fixes: 384
@Dangerjohn Yep, as @adam945 points out, there is a Major Service Outage in your area, estimated tine to resolve being 10/12/21 - next Friday, although it may be cleared before then.
