No improvement
Fixes: 147
Re: No improvement
@BO55
As standard, the rDNS name of you IP Address is currently your broadband username, you might want to get that changed
Dan.
Fixes: 579
Re: No improvement
but I thought I would get more than the 32Mb I was getting on the 36Mb service.
@BO55 it doesnt work like that I'm afraid. Sync speed (and thus download speed) are limited either by the maximum for the product i.e 40Mb on the 36Mb service OR by the distance from the cabinet and line quality. So unless you are synching at the maximum 40Mb on a 36Mb service you will not get any increase when going to the Fibre extra product.
BO55
Re: No improvement
@MisterW But as I mentioned on my first post I have had more than 32Mb
BO55
Re: No improvement
@jab1  Will do.
Fixes: 579
Re: No improvement
@BO55 i dont doubt that, and with your line estimates you OUGHT to be getting better speeds but what I'm saying is that just changing products won't increase speeds.
As I said earlier The question is why is the synch only 35Mb ?
It suggests a fault somwhere
Fixes: 382
Re: No improvement
@MisterW My thoughts too - but I can't see where - wonder if a current GEA would reveal anything?
Just noticed the SNR figures are missing from the Help Desk page - AND the xDSL uptime looks horribly low.
Fixes: 579
Re: No improvement
@jab1  yes a gea would show whether the low sync is due to the line being capped or not. Hopefully one of tte help team will oblige shortly...
BO55
Re: No improvement
Interestingly my speed has now increased to more like what I expected. The openreach engineer said this morning that I may lose connection when he closes the job. I had a text at 4:30 to say the job had now been closed. Or, The Help desk has done something.
7Mb faster than I've had for a few years
Fixes: 382
Re: No improvement
@BO55 Still looks to me like you are on a 40/10 setting, but hopefully one of the Help team will provide a GEA test to prove/disprove my theory.
Fixes: 1,662
Re: No improvement
I've taken a look into this for you and it looks like your line was reset automatically overnight, possibly after the engineer closed the job. Testing your line is showing your connection is on the right profile: "0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off"
Yesterday it was "Downstream: 0.128M-35M with Retransmission (Low). Upstream: 0.128M-20M with no error protection"
I'll attach below a copy of the testing I've run but let me know if you've got further queries.
GEA Test Detail
Circuit ID NA Service ID [redacted]
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 42.9 Mbps
Upstream Speed 7.2 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Cross Talk Not Detected
Estimated Line Length In Metres 735.4
Upstream Rate Assessment Low
Downstream Rate Assessment Reasonable
Technology VDSL
Current 15Min Bin Retrains 0
Last 15Min Bin Retrains 0
DP Type External
Profile Name 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2022-03-10T04:30:00
Parameters MIN MAX AVG
Down Stream Line Rate 42.9 Mbps 42.9 Mbps 42.9 Mbps
Up Stream Line Rate 7.1 Mbps 7.1 Mbps 7.1 Mbps
Up Time 900.0 Sec 900.0 Sec 900.0 Sec
Retrains 0.0 0.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2022-03-10T09:35:42Z 2022-03-10T09:50:42Z
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
BO55
Re: No improvement
Many thanks.
