Newly installed FTTP under 1MBPS
jwalowe76
Hi Everyone,
I kind of tearing my hair out here... Sorry for the long rant:
TLDR: New FTTP connection installed, ONT getting 160mbps down, 30 up), Plusnet Hub Two only putting out 1mbps or less download but consistent 30ish up. Openreach say all is well and it's a Plusnet issue, Plusnet saying it's Openreach.
- We had full fibre to the premises installed by a very kind Openreach engineer on June 28th. She checked the line and all was working perfectly. She left. Email from Plusnet to say all is up-and-running. Router plugged in and getting less than 1mbps download but 20-30 up.
- Called Plusnet helpline the next day and spoke to the very helpful Damien. Did all the things such as a speed tests, factory reset etc. Line checked from Plusnet side and no fault found, so a new router was ordered.
- New router arrives. Plugged in with new cables etc. Problem persists. Call Plusnet, Openreach engineer booked for the 4th.
- Joy! On the afternoon of Wednesday 3rd it all starts to work perfectly! Engineer visit cancelled.
- Less joy: next day back to less than 1mbps down (still 20-30 up).
- Day after it works again.
- Day after that it's back to sub 1MBPS down and remains that way until now.
- More calls to Plusnet: still looking good from their side. Engineer now re-booked for July 10th
- July 10th, another very nice Openreach engineer comes. He tests the incoming cable, all perfect, no fault. Tests ONT box, all good with that, but replaces it anyway for good measure. All great incoming to ONT (160mbps down, 30 up), but speed from router now a record 0.04MBPS down, 30+ up. He calls Openreach Second Line who can find no fault and send a report to Plusnet along with the engineer's report. All is well with the line and so he thinks it has to by a problem with my Profile, which can only be reset by Plusnet.
- I call Plusnet and explain my problem yet another person. He can't see Second Line's report but looks at the engineer's report, which he finds unhelpful. Tells me he needs to call Openreach but they're now closed for the day, but he will do so first thing and call me back.
- Next day: No call back
- I call again and now speak to William. It turns out my representative from yesterday has had "his workday re-assigned" so is no longer following up. William can't help, but very helpfully says he will seek out someone who can. It seems the engineer's report has now gone from the system. Also the engineer's visit the previous day is now marked as being missed. I briefly think I may have hallucinated him, but I'm pretty sure he came as he left written notes... I'm promised a call back.
- No call back
- Get a text saying an Openreach engineer is book to come tomorrow morning. Highly inconvenient, but I change my plans nevertheless as I need working internet for my job.
- I call back to suggest that the engineer will probably find everything the same, but I'm told that unless I have had two engineer visits, they can't elevate the problem.
- I get an email an hour later from Mark, saying that they hope the problem will be sorted by July 15th and that a member of the faults team will be in contact. I'm not holding my breath.
 So, it seems that there is nothing wrong with the supply coming into the house, and the router and cables have all been replaced. That only leaves sorting on the provisioning side from Plusnet (my Profile) or some other issue like my supply is banded/limited. Or am I missing something? An issue with router firmware or settings?
How do I get Plusnet to actually look in detail at their side and get this fixed?
Any help (or just comfort) gratefully received!
James
Tags (1)
57 REPLIES 57
Fixes: 569
Re: Newly installed FTTP under 1MBPS
@jwalowe76 Rubbish! Plusnet don't have any profiling, well not unless you have a static IP ?
Are you a new Plusnet customer ?
Are these speeds wired or wireless ?
Tags (1)
jwalowe76
Thanks for your speedy reply, MisterW!
Yes, I'm a new customer on a brand new FTTP install. ONT is pumping out 160mbps, router 0.04.
No, no static IP, and these are wired speeds. Replaced Plusnet Hub Two router as well, so it's not that that's on the fritz either.
The weird thing is that it worked perfectly for about a day and a half, which suggests that it's not the router but something on the supply end.
Seems to be a head-scratcher all round...
Tags (1)
Mustrum
Fixes: 81
@jwalowe76  How are you measuring the speeds from the ONT?
The connection to the router should show 1000Mbps.
Is there anything else connected to the router that could be downloading content when you are doing these speed tests?
Tags (1)
jwalowe76
The Openreach engineer measured the 160Mbps from the ONT. Router stats do indeed show a WAN link speed of 1000Mbps.
No nothing else connected to the router. Also the same recorded on the engineer's laptop as well.
Tags (1)
Mustrum
Fixes: 81
OK, what about the ethernet cable specs? And are you running anything over powerlines?
Could you post a copy of the advanced/technical log showing the page with the WAN connection speed and other info?
Tags (1)
jwalowe76
I’m using the Ethernet cables supplied with the (now two) routers. Nothing over powerlines.
I’m out now but will post the tech log when I get back. Excuse my ignorance on this, but is there anything in that that I should redact before publishing?!
Tags (1)
Fixes: 374
No.
Tags (1)
Mustrum
Fixes: 81
@jwalowe76   for the page I am thinking of, you might want to hide the username and WiFi Names but that is about it.
Tags (1)
Fixes: 374
Sorry, @Mustrum - I mis-thought it was the error log being referred to above Embarrassed
Tags (1)
Mustrum
Fixes: 81
@jab1  that may well be next, but first just wanted to check the equivalent of the Help Desk page
Tags (1)
markhawkin
Aspiring Champion
Fixes: 20
@jwalowe76
It's a very long shot, but you don't still have anything associated with the system prior to the full fibre install powered or connected do you (old router etc.)?
If so it would be worth disconnecting.
Tags (1)
jwalowe76
Thanks Mark, No, there was no prior system - we're so out there and far from the exchange that broadband wasn't an option. We've been using a very unstable 4g router.
Tags (1)
jwalowe76
Here it is some if its glory - the system won't take more than 50,000 characters. The firewall off/on was me trying to work out what's going on. 23:15:21, 11 Jul. admin login success from 192.168.1.115 23:14:40, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 23:14:33, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 23:14:33, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl1) 23:14:27, 11 Jul. 2.4G client Mac: 16:F6:09:E1:79:B8 Deauthentications (Reason:Deauthenticated because sending station is leaving (or has left) IBSS or ESS) 23:14:20, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 23:14:20, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl0) 23:14:20, 11 Jul. Self roaming might be occurring... Deauth original one... 23:11:04, 11 Jul. DHCP device Connected: 192.168.1.115, a0:78:17:7b:2f:4c, MacBook-Pro-2 23:11:04, 11 Jul. 5G Client associate from a0:78:17:7b:2f:4c (IP=192.168.1.115) RSSI=-49, Rate=866Mbps, host MacBook-Pro-2 23:11:04, 11 Jul. LAN [ADD] ARP 192.168.1.115 with a0:78:17:7b:2f:4c from br0(wl0) 23:11:03, 11 Jul. ARP [add] br0(wl0) 192.168.1.115 a0:78:17:7b:2f:4c 23:11:03, 11 Jul. Receive a DHCP request 23:04:33, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 23:04:26, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 23:04:26, 11 Jul. 2.4G Client associate from 16:f6:09:e1:79:b8 (IP=192.168.1.195) RSSI=-83, Rate=52Mbps, host 23:04:26, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl1) 23:04:26, 11 Jul. Receive a DHCP request 23:00:02, 11 Jul. DoS(UDP Loopback): IN=ppp0 OUT= MAC= src=152.32.219.102 DST=31.185.231.126 LEN=36 TOS=0x00 PREC=0x00 TTL=236 ID=0 DF PROTO=UDP SPT=59084 DPT=7 LEN=16 MARK=0x8000000 23:00:02, 11 Jul. DoS(Port Scanning): IN=ppp0 OUT= MAC= src=159.192.104.79 DST=31.185.231.126 LEN=60 TOS=0x00 PREC=0x00 TTL=46 ID=3832 DF PROTO=TCP SPT=19958 DPT=17793 WINDOW=0 RES=0x00 URG ACK PSH RST SYN FIN URGP=893 MARK=0x8000000 23:00:02, 11 Jul. DoS(Spoofing): IN=ppp0 OUT= MAC= src=159.192.104.79 DST=31.185.231.126 LEN=60 TOS=0x00 PREC=0x00 TTL=46 ID=3832 DF PROTO=TCP SPT=19958 DPT=17793 WINDOW=0 RES=0x00 URG ACK PSH RST SYN FIN URGP=893 MARK=0x8000000 23:00:02, 11 Jul. DoS(Spoofing): IN=ppp0 OUT= MAC= src=159.192.104.79 DST=31.185.231.126 LEN=60 TOS=0x00 PREC=0x00 TTL=46 ID=3832 DF PROTO=TCP SPT=19958 DPT=17793 WINDOW=0 RES=0x00 URG ACK PSH RST SYN FIN URGP=893 MARK=0x8000000 20:00:02, 11 Jul. DoS(Port Scanning): IN=ppp0 OUT= MAC= src=159.192.106.207 DST=31.185.231.126 LEN=60 TOS=0x00 PREC=0x00 TTL=46 ID=22059 DF PROTO=TCP SPT=11944 DPT=62466 WINDOW=0 RES=0x00 URG ACK PSH RST SYN FIN URGP=63838 MARK=0x8000000 20:00:02, 11 Jul. DoS(Spoofing): IN=ppp0 OUT= MAC= src=159.192.106.207 DST=31.185.231.126 LEN=60 TOS=0x00 PREC=0x00 TTL=46 ID=22059 DF PROTO=TCP SPT=11944 DPT=62466 WINDOW=0 RES=0x00 URG ACK PSH RST SYN FIN URGP=63838 MARK=0x8000000 20:00:02, 11 Jul. DoS(Spoofing): IN=ppp0 OUT= MAC= src=159.192.106.207 DST=31.185.231.126 LEN=60 TOS=0x00 PREC=0x00 TTL=46 ID=22059 DF PROTO=TCP SPT=11944 DPT=62466 WINDOW=0 RES=0x00 URG ACK PSH RST SYN FIN URGP=63838 MARK=0x8000000 19:00:02, 11 Jul. DoS(Port Scanning): IN=ppp0 OUT= MAC= src=159.192.106.207 DST=31.185.231.126 LEN=60 TOS=0x00 PREC=0x00 TTL=46 ID=52188 DF PROTO=TCP SPT=40133 DPT=14528 WINDOW=0 RES=0x00 URG ACK PSH RST SYN FIN URGP=46987 MARK=0x8000000 19:00:02, 11 Jul. DoS(Spoofing): IN=ppp0 OUT= MAC= src=159.192.106.207 DST=31.185.231.126 LEN=60 TOS=0x00 PREC=0x00 TTL=46 ID=52188 DF PROTO=TCP SPT=40133 DPT=14528 WINDOW=0 RES=0x00 URG ACK PSH RST SYN FIN URGP=46987 MARK=0x8000000 19:00:02, 11 Jul. DoS(Spoofing): IN=ppp0 OUT= MAC= src=159.192.106.207 DST=31.185.231.126 LEN=60 TOS=0x00 PREC=0x00 TTL=46 ID=52188 DF PROTO=TCP SPT=40133 DPT=14528 WINDOW=0 RES=0x00 URG ACK PSH RST SYN FIN URGP=46987 MARK=0x8000000 18:26:08, 11 Jul. 2.4G client Mac: 16:F6:09:E1:79:B8 Deauthentications (Reason:Disassociated due to inactivity ) 18:24:45, 11 Jul. DHCP device Disconnected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 18:24:45, 11 Jul. LAN [DEL] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0 18:24:41, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 18:23:57, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 18:23:57, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl1) 18:23:57, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 18:23:40, 11 Jul. DHCP device Disconnected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 18:23:40, 11 Jul. LAN [DEL] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0 18:23:36, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 18:19:34, 11 Jul. ARP [del] br0 192.168.1.115 a0:78:17:7b:2f:4c 18:18:59, 11 Jul. DHCP device Disconnected: 192.168.1.115, a0:78:17:7b:2f:4c, MacBook-Pro-2 18:18:59, 11 Jul. LAN [DEL] ARP 192.168.1.115 with a0:78:17:7b:2f:4c from br0 18:18:13, 11 Jul. admin timeout from 192.168.1.115 18:18:07, 11 Jul. DHCP device Connected: 192.168.1.115, a0:78:17:7b:2f:4c, MacBook-Pro-2 18:18:07, 11 Jul. 5G Client associate from a0:78:17:7b:2f:4c (IP=192.168.1.115) RSSI=-53, Rate=866Mbps, host MacBook-Pro-2 18:18:07, 11 Jul. LAN [ADD] ARP 192.168.1.115 with a0:78:17:7b:2f:4c from br0(wl0) 18:18:07, 11 Jul. ARP [add] br0(wl0) 192.168.1.115 a0:78:17:7b:2f:4c 18:18:07, 11 Jul. Receive a DHCP request 18:15:23, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 18:15:23, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl1) 18:15:23, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 18:15:19, 11 Jul. DHCP device Disconnected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 18:15:19, 11 Jul. LAN [DEL] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0 18:15:15, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 18:06:59, 11 Jul. ARP [del] br0 192.168.1.115 a0:78:17:7b:2f:4c 18:06:22, 11 Jul. DHCP device Disconnected: 192.168.1.115, a0:78:17:7b:2f:4c, MacBook-Pro-2 18:06:22, 11 Jul. LAN [DEL] ARP 192.168.1.115 with a0:78:17:7b:2f:4c from br0 18:05:35, 11 Jul. DHCP device Connected: 192.168.1.115, a0:78:17:7b:2f:4c, MacBook-Pro-2 18:05:35, 11 Jul. 5G Client associate from a0:78:17:7b:2f:4c (IP=192.168.1.115) RSSI=-52, Rate=866Mbps, host MacBook-Pro-2 18:05:34, 11 Jul. LAN [ADD] ARP 192.168.1.115 with a0:78:17:7b:2f:4c from br0(wl0) 18:05:34, 11 Jul. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT 18:05:34, 11 Jul. ARP [add] br0(wl0) 192.168.1.115 a0:78:17:7b:2f:4c 18:05:34, 11 Jul. Receive a DHCP request 18:03:05, 11 Jul. ARP [del] br0 192.168.1.115 a0:78:17:7b:2f:4c 18:03:00, 11 Jul. DHCP device Disconnected: 192.168.1.115, a0:78:17:7b:2f:4c, MacBook-Pro-2 18:02:59, 11 Jul. LAN [DEL] ARP 192.168.1.115 with a0:78:17:7b:2f:4c from br0 18:00:25, 11 Jul. admin login success from 192.168.1.115 17:51:36, 11 Jul. 5G Client associate from a0:78:17:7b:2f:4c (IP=192.168.1.115) RSSI=-52, Rate=866Mbps, host MacBook-Pro-2 17:51:36, 11 Jul. Receive a DHCP request 17:51:10, 11 Jul. admin timeout from 192.168.1.115 17:48:51, 11 Jul. DHCP device Connected: 192.168.1.115, a0:78:17:7b:2f:4c, MacBook-Pro-2 17:48:51, 11 Jul. 5G Client associate from a0:78:17:7b:2f:4c (IP=192.168.1.115) RSSI=-53, Rate=866Mbps, host MacBook-Pro-2 17:48:51, 11 Jul. LAN [ADD] ARP 192.168.1.115 with a0:78:17:7b:2f:4c from br0(wl0) 17:48:51, 11 Jul. ARP [add] br0(wl0) 192.168.1.115 a0:78:17:7b:2f:4c 17:48:51, 11 Jul. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT 17:48:50, 11 Jul. Receive a DHCP request 17:28:55, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 17:28:55, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl1) 17:28:55, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 17:28:36, 11 Jul. DHCP device Disconnected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 17:28:35, 11 Jul. LAN [DEL] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0 17:28:31, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 17:17:39, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 17:17:39, 11 Jul. 2.4G Client associate from 16:f6:09:e1:79:b8 (IP=192.168.1.195) RSSI=-73, Rate=130Mbps, host 17:17:39, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl1) 17:17:39, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 17:17:39, 11 Jul. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT 17:17:39, 11 Jul. Receive a DHCP request 17:11:27, 11 Jul. NTP synchronization success 17:11:27, 11 Jul. NTP Server: ntp.plus.net 17:11:27, 11 Jul. DoS(Port Scanning): IN=ppp0 OUT= MAC= src=1.34.85.243 DST=31.185.231.126 LEN=60 TOS=0x00 PREC=0x00 TTL=46 ID=45340 DF PROTO=TCP SPT=16163 DPT=38135 WINDOW=0 RES=0x00 URG ACK PSH RST SYN FIN URGP=28940 MARK=0x8000000 17:11:27, 11 Jul. DoS(Spoofing): IN=ppp0 OUT= MAC= src=1.34.85.243 DST=31.185.231.126 LEN=60 TOS=0x00 PREC=0x00 TTL=46 ID=45340 DF PROTO=TCP SPT=16163 DPT=38135 WINDOW=0 RES=0x00 URG ACK PSH RST SYN FIN URGP=28940 MARK=0x8000000 17:11:27, 11 Jul. DoS(Spoofing): IN=ppp0 OUT= MAC= src=1.34.85.243 DST=31.185.231.126 LEN=60 TOS=0x00 PREC=0x00 TTL=46 ID=45340 DF PROTO=TCP SPT=16163 DPT=38135 WINDOW=0 RES=0x00 URG ACK PSH RST SYN FIN URGP=28940 MARK=0x8000000 17:11:14, 11 Jul. NTP synchronization start 17:00:03, 11 Jul. DoS(Port Scanning): IN=ppp0 OUT= MAC= src=159.192.104.79 DST=31.185.231.126 LEN=60 TOS=0x00 PREC=0x00 TTL=46 ID=52565 DF PROTO=TCP SPT=58422 DPT=58199 WINDOW=0 RES=0x00 URG ACK PSH RST SYN FIN URGP=54057 MARK=0x8000000 17:00:03, 11 Jul. DoS(Spoofing): IN=ppp0 OUT= MAC= src=159.192.104.79 DST=31.185.231.126 LEN=60 TOS=0x00 PREC=0x00 TTL=46 ID=52565 DF PROTO=TCP SPT=58422 DPT=58199 WINDOW=0 RES=0x00 URG ACK PSH RST SYN FIN URGP=54057 MARK=0x8000000 17:00:03, 11 Jul. DoS(Spoofing): IN=ppp0 OUT= MAC= src=159.192.104.79 DST=31.185.231.126 LEN=60 TOS=0x00 PREC=0x00 TTL=46 ID=52565 DF PROTO=TCP SPT=58422 DPT=58199 WINDOW=0 RES=0x00 URG ACK PSH RST SYN FIN URGP=54057 MARK=0x8000000 16:58:28, 11 Jul. ARP [del] br0 192.168.1.115 a0:78:17:7b:2f:4c 16:57:50, 11 Jul. DHCP device Disconnected: 192.168.1.115, a0:78:17:7b:2f:4c, MacBook-Pro-2 16:57:49, 11 Jul. LAN [DEL] ARP 192.168.1.115 with a0:78:17:7b:2f:4c from br0 16:40:48, 11 Jul. admin login success from 192.168.1.115 16:39:54, 11 Jul. admin timeout from 192.168.1.115 16:39:54, 11 Jul. 5G Client associate from a0:78:17:7b:2f:4c (IP=192.168.1.115) RSSI=-53, Rate=866Mbps, host MacBook-Pro-2 16:39:54, 11 Jul. Receive a DHCP request 16:39:53, 11 Jul. 5G Client associate from a0:78:17:7b:2f:4c (IP=192.168.1.115) RSSI=-53, Rate=866Mbps, host MacBook-Pro-2 16:39:52, 11 Jul. Receive a DHCP request 16:39:52, 11 Jul. DHCP device Connected: 192.168.1.115, a0:78:17:7b:2f:4c, MacBook-Pro-2 16:39:52, 11 Jul. 5G Client associate from a0:78:17:7b:2f:4c (IP=192.168.1.115) RSSI=-53, Rate=866Mbps, host MacBook-Pro-2 16:39:52, 11 Jul. LAN [ADD] ARP 192.168.1.115 with a0:78:17:7b:2f:4c from br0(wl0) 16:39:51, 11 Jul. ARP [add] br0(wl0) 192.168.1.115 a0:78:17:7b:2f:4c 16:39:51, 11 Jul. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT 16:39:51, 11 Jul. Receive a DHCP request 16:35:48, 11 Jul. ARP [del] br0 192.168.1.115 a0:78:17:7b:2f:4c 16:35:09, 11 Jul. DHCP device Disconnected: 192.168.1.115, a0:78:17:7b:2f:4c, MacBook-Pro-2 16:35:09, 11 Jul. LAN [DEL] ARP 192.168.1.115 with a0:78:17:7b:2f:4c from br0 16:34:55, 11 Jul. DHCP device Connected: 192.168.1.115, a0:78:17:7b:2f:4c, MacBook-Pro-2 16:34:55, 11 Jul. 5G Client associate from a0:78:17:7b:2f:4c (IP=192.168.1.115) RSSI=-53, Rate=866Mbps, host MacBook-Pro-2 16:34:54, 11 Jul. LAN [ADD] ARP 192.168.1.115 with a0:78:17:7b:2f:4c from br0(wl0) 16:34:54, 11 Jul. ARP [add] br0(wl0) 192.168.1.115 a0:78:17:7b:2f:4c 16:34:54, 11 Jul. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT 16:34:54, 11 Jul. Receive a DHCP request 16:04:28, 11 Jul. ARP [del] br0 192.168.1.68 fa:55:22:01:04:66 16:04:17, 11 Jul. LAN [DEL] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0 15:55:06, 11 Jul. 2.4G client Mac: 16:F6:09:E1:79:B8 Deauthentications (Reason:Disassociated due to inactivity ) 15:53:53, 11 Jul. DHCP device Disconnected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 15:53:53, 11 Jul. LAN [DEL] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0 15:53:49, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 15:50:25, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 15:49:45, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 15:49:44, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl1) 15:49:33, 11 Jul. ARP [add] br0(wl0) 192.168.1.195 16:f6:09:e1:79:b8 15:48:52, 11 Jul. 2.4G client Mac: 16:F6:09:E1:79:B8 Deauthentications (Reason:Deauthenticated because sending station is leaving (or has left) IBSS or ESS) 15:48:48, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 15:48:48, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl0) 15:48:46, 11 Jul. Self roaming might be occurring... Deauth original one... 15:36:26, 11 Jul. ARP [del] br0 192.168.1.115 a0:78:17:7b:2f:4c 15:35:59, 11 Jul. DHCP device Disconnected: 192.168.1.115, a0:78:17:7b:2f:4c, MacBook-Pro-2 15:35:59, 11 Jul. LAN [DEL] ARP 192.168.1.115 with a0:78:17:7b:2f:4c from br0 15:34:04, 11 Jul. DHCP device Connected: 192.168.1.68, fa:55:22:01:04:66, unknown 15:34:04, 11 Jul. LAN [ADD] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0(wl1) 15:34:04, 11 Jul. ARP [add] br0(wl1) 192.168.1.68 fa:55:22:01:04:66 15:34:03, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 15:34:03, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl1) 15:34:03, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 15:33:37, 11 Jul. DHCP device Disconnected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 15:33:37, 11 Jul. DHCP device Disconnected: 192.168.1.68, fa:55:22:01:04:66, unknown 15:33:37, 11 Jul. LAN [DEL] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0 15:33:37, 11 Jul. LAN [DEL] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0 15:33:33, 11 Jul. ARP [add] br0(wl0) 192.168.1.115 a0:78:17:7b:2f:4c 15:33:33, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 15:33:32, 11 Jul. ARP [del] br0 192.168.1.68 fa:55:22:01:04:66 15:33:32, 11 Jul. ARP [del] br0 192.168.1.115 a0:78:17:7b:2f:4c 15:32:23, 11 Jul. DHCP device Connected: 192.168.1.115, a0:78:17:7b:2f:4c, MacBook-Pro-2 15:32:23, 11 Jul. 5G Client associate from a0:78:17:7b:2f:4c (IP=192.168.1.115) RSSI=-54, Rate=866Mbps, host MacBook-Pro-2 15:32:23, 11 Jul. LAN [ADD] ARP 192.168.1.115 with a0:78:17:7b:2f:4c from br0(wl0) 15:32:23, 11 Jul. ARP [add] br0(wl0) 192.168.1.115 a0:78:17:7b:2f:4c 15:32:23, 11 Jul. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT 15:32:23, 11 Jul. Receive a DHCP request 15:31:22, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 15:31:22, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 15:30:43, 11 Jul. ARP [del] br0 192.168.1.115 a0:78:17:7b:2f:4c 15:30:40, 11 Jul. DHCP device Disconnected: 192.168.1.115, a0:78:17:7b:2f:4c, MacBook-Pro-2 15:30:40, 11 Jul. LAN [DEL] ARP 192.168.1.115 with a0:78:17:7b:2f:4c from br0 15:29:17, 11 Jul. DHCP device Connected: 192.168.1.115, a0:78:17:7b:2f:4c, MacBook-Pro-2 15:29:17, 11 Jul. 5G Client associate from a0:78:17:7b:2f:4c (IP=192.168.1.115) RSSI=-56, Rate=866Mbps, host MacBook-Pro-2 15:29:17, 11 Jul. LAN [ADD] ARP 192.168.1.115 with a0:78:17:7b:2f:4c from br0(wl0) 15:29:17, 11 Jul. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT 15:29:17, 11 Jul. ARP [add] br0(wl0) 192.168.1.115 a0:78:17:7b:2f:4c 15:29:17, 11 Jul. Receive a DHCP request 15:28:49, 11 Jul. ARP [del] br0 192.168.1.115 a0:78:17:7b:2f:4c 15:28:28, 11 Jul. DHCP device Disconnected: 192.168.1.115, a0:78:17:7b:2f:4c, MacBook-Pro-2 15:28:28, 11 Jul. LAN [DEL] ARP 192.168.1.115 with a0:78:17:7b:2f:4c from br0 15:26:54, 11 Jul. admin login success from 192.168.1.115 15:26:20, 11 Jul. admin timeout from 192.168.1.115 15:26:15, 11 Jul. DHCP device Connected: 192.168.1.115, a0:78:17:7b:2f:4c, MacBook-Pro-2 15:26:15, 11 Jul. 5G Client associate from a0:78:17:7b:2f:4c (IP=192.168.1.115) RSSI=-53, Rate=866Mbps, host MacBook-Pro-2 15:26:14, 11 Jul. LAN [ADD] ARP 192.168.1.115 with a0:78:17:7b:2f:4c from br0(wl0) 15:26:14, 11 Jul. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT 15:26:14, 11 Jul. ARP [add] br0(wl0) 192.168.1.115 a0:78:17:7b:2f:4c 15:26:14, 11 Jul. Receive a DHCP request 15:18:16, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 15:18:14, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 15:17:37, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 15:17:36, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 15:16:59, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 15:16:59, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 15:16:21, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 15:16:21, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl1) 15:16:21, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 15:16:03, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 15:13:24, 11 Jul. ARP [add] br0(wl1) 192.168.1.68 fa:55:22:01:04:66 15:13:09, 11 Jul. DHCP device Connected: 192.168.1.68, fa:55:22:01:04:66, unknown 15:13:09, 11 Jul. LAN [ADD] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0(wl1) 15:11:50, 11 Jul. DHCP device Disconnected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 15:11:50, 11 Jul. LAN [DEL] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0 15:11:48, 11 Jul. 2.4G client Mac: 16:F6:09:E1:79:B8 Deauthentications (Reason:Disassociated due to inactivity ) 15:09:04, 11 Jul. ARP [del] br0 192.168.1.115 a0:78:17:7b:2f:4c 15:08:36, 11 Jul. DHCP device Disconnected: 192.168.1.115, a0:78:17:7b:2f:4c, MacBook-Pro-2 15:08:36, 11 Jul. LAN [DEL] ARP 192.168.1.115 with a0:78:17:7b:2f:4c from br0 15:08:04, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 15:08:04, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl1) 15:08:04, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 15:08:03, 11 Jul. ARP [add] br0(wl0) 192.168.1.115 a0:78:17:7b:2f:4c 15:07:55, 11 Jul. DHCP device Connected: 192.168.1.115, a0:78:17:7b:2f:4c, MacBook-Pro-2 15:07:55, 11 Jul. 5G Client associate from a0:78:17:7b:2f:4c (IP=192.168.1.115) RSSI=-56, Rate=780Mbps, host MacBook-Pro-2 15:07:55, 11 Jul. LAN [ADD] ARP 192.168.1.115 with a0:78:17:7b:2f:4c from br0(wl0) 15:07:55, 11 Jul. Receive a DHCP request 15:07:55, 11 Jul. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT 15:06:26, 11 Jul. DHCP device Disconnected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 15:06:26, 11 Jul. LAN [DEL] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0 15:06:22, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 15:05:35, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 15:05:29, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 15:05:29, 11 Jul. 2.4G Client associate from 16:f6:09:e1:79:b8 (IP=192.168.1.195) RSSI=-83, Rate=104Mbps, host 15:05:29, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl1) 15:05:29, 11 Jul. Receive a DHCP request 15:04:59, 11 Jul. ARP [del] br0 192.168.1.115 a0:78:17:7b:2f:4c 15:04:14, 11 Jul. DHCP device Disconnected: 192.168.1.115, a0:78:17:7b:2f:4c, MacBook-Pro-2 15:04:13, 11 Jul. LAN [DEL] ARP 192.168.1.115 with a0:78:17:7b:2f:4c from br0 15:00:49, 11 Jul. Firewall change to Level: Default 15:00:34, 11 Jul. Firewall change to Level: Disabled 14:59:02, 11 Jul. admin login success from 192.168.1.115 14:57:43, 11 Jul. DHCP device Connected: 192.168.1.115, a0:78:17:7b:2f:4c, MacBook-Pro-2 14:57:43, 11 Jul. 5G Client associate from a0:78:17:7b:2f:4c (IP=192.168.1.115) RSSI=-51, Rate=866Mbps, host MacBook-Pro-2 14:57:43, 11 Jul. LAN [ADD] ARP 192.168.1.115 with a0:78:17:7b:2f:4c from br0(wl0) 14:57:42, 11 Jul. ARP [add] br0(wl0) 192.168.1.115 a0:78:17:7b:2f:4c 14:57:42, 11 Jul. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT 14:57:42, 11 Jul. Receive a DHCP request 14:50:14, 11 Jul. ARP [del] br0 192.168.1.115 a0:78:17:7b:2f:4c 14:49:43, 11 Jul. DHCP device Disconnected: 192.168.1.115, a0:78:17:7b:2f:4c, MacBook-Pro-2 14:49:42, 11 Jul. LAN [DEL] ARP 192.168.1.115 with a0:78:17:7b:2f:4c from br0 14:41:18, 11 Jul. 2.4G client Mac: 16:F6:09:E1:79:B8 Deauthentications (Reason:Disassociated due to inactivity ) 14:39:51, 11 Jul. DHCP device Disconnected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 14:39:51, 11 Jul. LAN [DEL] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0 14:39:47, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 14:38:55, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 14:38:55, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl1) 14:38:55, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 14:38:52, 11 Jul. DHCP device Disconnected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 14:38:52, 11 Jul. LAN [DEL] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0 14:38:48, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 14:38:27, 11 Jul. ARP [add] br0(wl0) 192.168.1.115 a0:78:17:7b:2f:4c 14:38:21, 11 Jul. DHCP device Connected: 192.168.1.115, a0:78:17:7b:2f:4c, MacBook-Pro-2 14:38:21, 11 Jul. 5G Client associate from a0:78:17:7b:2f:4c (IP=192.168.1.115) RSSI=-53, Rate=866Mbps, host MacBook-Pro-2 14:38:20, 11 Jul. LAN [ADD] ARP 192.168.1.115 with a0:78:17:7b:2f:4c from br0(wl0) 14:38:20, 11 Jul. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT 14:38:20, 11 Jul. Receive a DHCP request 14:37:50, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 14:37:50, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl1) 14:37:50, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 14:37:24, 11 Jul. DHCP device Disconnected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 14:37:24, 11 Jul. LAN [DEL] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0 14:37:20, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 14:36:33, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 14:36:33, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl1) 14:36:33, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 14:36:25, 11 Jul. DHCP device Disconnected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 14:36:25, 11 Jul. LAN [DEL] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0 14:36:21, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 14:34:39, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 14:34:39, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl1) 14:34:39, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 14:34:28, 11 Jul. DHCP device Disconnected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 14:34:28, 11 Jul. LAN [DEL] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0 14:34:24, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 14:29:48, 11 Jul. ARP [del] br0 192.168.1.115 a0:78:17:7b:2f:4c 14:29:28, 11 Jul. DHCP device Disconnected: 192.168.1.115, a0:78:17:7b:2f:4c, MacBook-Pro-2 14:29:27, 11 Jul. LAN [DEL] ARP 192.168.1.115 with a0:78:17:7b:2f:4c from br0 14:29:14, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 14:29:11, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 14:28:44, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 14:28:44, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl1) 14:28:44, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 14:28:37, 11 Jul. DHCP device Disconnected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 14:28:37, 11 Jul. LAN [DEL] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0 14:28:34, 11 Jul. DHCP device Connected: 192.168.1.115, a0:78:17:7b:2f:4c, MacBook-Pro-2 14:28:34, 11 Jul. 5G Client associate from a0:78:17:7b:2f:4c (IP=192.168.1.115) RSSI=-52, Rate=866Mbps, host MacBook-Pro-2 14:28:33, 11 Jul. LAN [ADD] ARP 192.168.1.115 with a0:78:17:7b:2f:4c from br0(wl0) 14:28:33, 11 Jul. ARP [add] br0(wl0) 192.168.1.115 a0:78:17:7b:2f:4c 14:28:33, 11 Jul. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT 14:28:33, 11 Jul. Receive a DHCP request 14:28:33, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 14:22:51, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 14:22:51, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl1) 14:22:51, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 14:21:56, 11 Jul. DHCP device Disconnected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 14:21:56, 11 Jul. LAN [DEL] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0 14:21:52, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 14:21:21, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 14:21:20, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl1) 14:21:20, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 14:21:14, 11 Jul. DHCP device Disconnected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 14:21:13, 11 Jul. LAN [DEL] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0 14:21:09, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 14:18:54, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 14:18:54, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl1) 14:18:54, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 14:18:52, 11 Jul. DHCP device Disconnected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 14:18:52, 11 Jul. LAN [DEL] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0 14:18:48, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 14:18:10, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 14:18:09, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl1) 14:18:09, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 14:17:51, 11 Jul. DHCP device Disconnected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 14:17:51, 11 Jul. LAN [DEL] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0 14:17:46, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 14:16:28, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 14:16:26, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 14:15:11, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 14:15:11, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl1) 14:15:11, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 14:15:02, 11 Jul. DHCP device Disconnected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 14:15:01, 11 Jul. LAN [DEL] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0 14:14:57, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 14:12:02, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 14:12:02, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl1) 14:12:02, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 14:12:02, 11 Jul. DHCP device Disconnected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 14:12:02, 11 Jul. LAN [DEL] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0 14:11:58, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 14:05:32, 11 Jul. ARP [del] br0 192.168.1.115 a0:78:17:7b:2f:4c 14:05:05, 11 Jul. DHCP device Disconnected: 192.168.1.115, a0:78:17:7b:2f:4c, MacBook-Pro-2 14:05:05, 11 Jul. LAN [DEL] ARP 192.168.1.115 with a0:78:17:7b:2f:4c from br0 14:04:57, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 14:04:54, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 14:04:54, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl1) 14:04:52, 11 Jul. ARP [add] br0(wl0) 192.168.1.115 a0:78:17:7b:2f:4c 14:04:45, 11 Jul. DHCP device Connected: 192.168.1.115, a0:78:17:7b:2f:4c, MacBook-Pro-2 14:04:45, 11 Jul. 5G Client associate from a0:78:17:7b:2f:4c (IP=192.168.1.115) RSSI=-55, Rate=780Mbps, host MacBook-Pro-2 14:04:45, 11 Jul. LAN [ADD] ARP 192.168.1.115 with a0:78:17:7b:2f:4c from br0(wl0) 14:04:45, 11 Jul. Receive a DHCP request 14:03:32, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 14:03:32, 11 Jul. 5G Client associate from 16:f6:09:e1:79:b8 (IP=192.168.1.195) RSSI=-47, Rate=780Mbps, host 14:03:32, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl0) 14:03:32, 11 Jul. ARP [add] br0(wl0) 192.168.1.195 16:f6:09:e1:79:b8 14:03:32, 11 Jul. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT 14:03:32, 11 Jul. Receive a DHCP request 14:03:13, 11 Jul. DHCP device Connected: 192.168.1.68, fa:55:22:01:04:66, unknown 14:03:13, 11 Jul. LAN [ADD] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0(wl0) 14:03:13, 11 Jul. ARP [add] br0(wl0) 192.168.1.68 fa:55:22:01:04:66 14:03:09, 11 Jul. DHCP device Disconnected: 192.168.1.68, fa:55:22:01:04:66, unknown 14:03:08, 11 Jul. LAN [DEL] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0 14:03:07, 11 Jul. 2.4G client Mac: FA:55:22:01:04:66 Deauthentications (Reason:Deauthenticated because sending station is leaving (or has left) IBSS or ESS) 14:03:07, 11 Jul. Self roaming might be occurring... Deauth original one... 14:03:07, 11 Jul. DHCP device Connected: 192.168.1.68, fa:55:22:01:04:66, unknown 14:03:06, 11 Jul. 2.4G Client associate from fa:55:22:01:04:66 (IP=192.168.1.68) RSSI=-64, Rate=130Mbps, host 14:03:06, 11 Jul. LAN [ADD] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0(wl1) 14:03:06, 11 Jul. Receive a DHCP request 14:03:05, 11 Jul. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT 13:44:42, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 13:44:36, 11 Jul. DHCP device Disconnected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 13:44:36, 11 Jul. LAN [DEL] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0 13:44:08, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 13:44:08, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl1) 13:44:08, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 13:43:33, 11 Jul. DHCP device Disconnected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 13:43:32, 11 Jul. LAN [DEL] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0 13:43:28, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 13:42:50, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 13:42:49, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl1) 13:42:49, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 13:42:38, 11 Jul. DHCP device Disconnected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 13:42:38, 11 Jul. LAN [DEL] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0 13:42:34, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 13:41:18, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 13:41:17, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 13:37:41, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 13:37:41, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl1) 13:37:41, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 13:37:22, 11 Jul. DHCP device Disconnected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 13:37:22, 11 Jul. LAN [DEL] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0 13:37:18, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 13:36:30, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 13:36:27, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 13:35:40, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 13:35:39, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl1) 13:35:39, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 13:35:29, 11 Jul. DHCP device Disconnected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 13:35:29, 11 Jul. LAN [DEL] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0 13:35:25, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 13:31:57, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 13:31:56, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl1) 13:31:56, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 13:31:50, 11 Jul. DHCP device Disconnected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 13:31:50, 11 Jul. LAN [DEL] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0 13:31:45, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 13:30:02, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 13:30:00, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 13:27:19, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 13:27:19, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl1) 13:27:19, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 13:27:18, 11 Jul. DHCP device Disconnected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 13:27:18, 11 Jul. LAN [DEL] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0 13:27:14, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 13:25:22, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 13:25:22, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl1) 13:25:22, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 13:25:00, 11 Jul. DHCP device Disconnected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 13:25:00, 11 Jul. LAN [DEL] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0 13:24:56, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 13:24:26, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 13:24:26, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl1) 13:24:26, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 13:24:26, 11 Jul. DHCP device Disconnected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 13:24:25, 11 Jul. LAN [DEL] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0 13:24:21, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 13:23:18, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 13:23:14, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 13:21:50, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 13:21:47, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 13:20:55, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 13:20:55, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl1) 13:20:55, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 13:20:41, 11 Jul. DHCP device Disconnected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 13:20:41, 11 Jul. LAN [DEL] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0 13:20:37, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 13:20:07, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 13:20:04, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 12:53:49, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 12:53:49, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl1) 12:53:49, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 12:52:58, 11 Jul. DHCP device Disconnected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 12:52:57, 11 Jul. LAN [DEL] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0 12:52:53, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 12:51:19, 11 Jul. DHCP device Connected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 12:51:19, 11 Jul. 2.4G Client associate from 16:f6:09:e1:79:b8 (IP=192.168.1.195) RSSI=-74, Rate=104Mbps, host 12:51:19, 11 Jul. LAN [ADD] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0(wl1) 12:51:19, 11 Jul. ARP [add] br0(wl1) 192.168.1.195 16:f6:09:e1:79:b8 12:51:19, 11 Jul. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT 12:51:18, 11 Jul. Receive a DHCP request 12:40:46, 11 Jul. ARP [del] br0 192.168.1.115 a0:78:17:7b:2f:4c 12:40:11, 11 Jul. DHCP device Disconnected: 192.168.1.115, a0:78:17:7b:2f:4c, MacBook-Pro-2 12:40:11, 11 Jul. LAN [DEL] ARP 192.168.1.115 with a0:78:17:7b:2f:4c from br0 12:39:56, 11 Jul. ARP [add] br0(wl0) 192.168.1.115 a0:78:17:7b:2f:4c 12:39:50, 11 Jul. DHCP device Connected: 192.168.1.115, a0:78:17:7b:2f:4c, MacBook-Pro-2 12:39:50, 11 Jul. 5G Client associate from a0:78:17:7b:2f:4c (IP=192.168.1.115) RSSI=-50, Rate=780Mbps, host MacBook-Pro-2 12:39:50, 11 Jul. LAN [ADD] ARP 192.168.1.115 with a0:78:17:7b:2f:4c from br0(wl0) 12:39:50, 11 Jul. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT 12:39:50, 11 Jul. Receive a DHCP request 12:39:35, 11 Jul. ARP [del] br0 192.168.1.115 a0:78:17:7b:2f:4c 12:39:22, 11 Jul. DHCP device Disconnected: 192.168.1.115, a0:78:17:7b:2f:4c, MacBook-Pro-2 12:39:22, 11 Jul. LAN [DEL] ARP 192.168.1.115 with a0:78:17:7b:2f:4c from br0 12:26:41, 11 Jul. ARP [del] br0 192.168.1.145 00:e0:4c:68:9f:62 12:26:14, 11 Jul. A device disconnected from Ethernet port 1 12:26:14, 11 Jul. Wire Lan Port 1 down, Speed 10 Mbps 12:26:14, 11 Jul. LAN [DEL] ARP 192.168.1.145 with 00:e0:4c:68:9f:62 from br0 12:22:51, 11 Jul. 2.4G WiFi auto selected channel 1 Bandwidth:20M(Reason:interference) 12:22:48, 11 Jul. 2.4G WiFi scan via ACSD(Reason:interference) 12:22:36, 11 Jul. ARP [add] br0(eth0) 192.168.1.145 00:e0:4c:68:9f:62 12:22:31, 11 Jul. DHCP device Connected: 192.168.1.145, 00:e0:4c:68:9f:62, MacBook-Pro-2 12:22:31, 11 Jul. DHCP lease issued 192.168.1.145 to 00:e0:4c:68:9f:62 MacBook-Pro-2, lease duration is 86400 seconds 12:22:28, 11 Jul. LAN [ADD] ARP 192.168.1.145 with 00:e0:4c:68:9f:62 from br0(eth0) 12:22:28, 11 Jul. 5G Client associate from a0:78:17:7b:2f:4c (IP=192.168.1.115) RSSI=-35, Rate=866Mbps, host 12:22:28, 11 Jul. Receive a DHCP request 12:22:24, 11 Jul. A device connected to Ethernet port 1 12:22:24, 11 Jul. Wire Lan Port 1 up, Speed 1000 Mbps 12:22:23, 11 Jul. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT 12:01:30, 11 Jul. 5G Client associate from a0:78:17:7b:2f:4c (IP=192.168.1.115) RSSI=-53, Rate=866Mbps, host MacBook-Pro-2 12:01:30, 11 Jul. DHCP device Connected: 192.168.1.115, a0:78:17:7b:2f:4c, MacBook-Pro-2 12:01:30, 11 Jul. LAN [ADD] ARP 192.168.1.115 with a0:78:17:7b:2f:4c from br0(wl0) 12:01:30, 11 Jul. ARP [add] br0(wl0) 192.168.1.115 a0:78:17:7b:2f:4c 12:01:29, 11 Jul. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT 12:01:29, 11 Jul. Receive a DHCP request 11:42:46, 11 Jul. 2.4G client Mac: FA:55:22:01:04:66 Deauthentications (Reason:Deauthenticated because sending station is leaving (or has left) IBSS or ESS) 11:39:20, 11 Jul. DHCP device Disconnected: 192.168.1.68, fa:55:22:01:04:66, unknown 11:39:20, 11 Jul. LAN [DEL] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0 11:39:16, 11 Jul. ARP [del] br0 192.168.1.68 fa:55:22:01:04:66 11:38:40, 11 Jul. ARP [add] br0(wl1) 192.168.1.68 fa:55:22:01:04:66 11:38:37, 11 Jul. ARP [del] br0 192.168.1.68 fa:55:22:01:04:66 11:36:17, 11 Jul. ARP [add] br0(wl1) 192.168.1.68 fa:55:22:01:04:66 11:36:16, 11 Jul. ARP [del] br0 192.168.1.68 fa:55:22:01:04:66 11:35:07, 11 Jul. DHCP device Connected: 192.168.1.68, fa:55:22:01:04:66, unknown 11:35:07, 11 Jul. LAN [ADD] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0(wl1) 11:35:07, 11 Jul. ARP [add] br0(wl1) 192.168.1.68 fa:55:22:01:04:66 11:33:56, 11 Jul. DHCP device Disconnected: 192.168.1.68, fa:55:22:01:04:66, unknown 11:33:56, 11 Jul. LAN [DEL] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0 11:33:52, 11 Jul. ARP [del] br0 192.168.1.68 fa:55:22:01:04:66 11:33:12, 11 Jul. ARP [add] br0(wl1) 192.168.1.68 fa:55:22:01:04:66 11:33:09, 11 Jul. ARP [del] br0 192.168.1.68 fa:55:22:01:04:66 11:32:28, 11 Jul. DHCP device Connected: 192.168.1.68, fa:55:22:01:04:66, unknown 11:32:28, 11 Jul. LAN [ADD] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0(wl1) 11:32:28, 11 Jul. ARP [add] br0(wl1) 192.168.1.68 fa:55:22:01:04:66 11:32:12, 11 Jul. DHCP device Disconnected: 192.168.1.68, fa:55:22:01:04:66, unknown 11:32:12, 11 Jul. LAN [DEL] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0 11:32:07, 11 Jul. ARP [del] br0 192.168.1.68 fa:55:22:01:04:66 11:30:48, 11 Jul. ARP [add] br0(wl1) 192.168.1.68 fa:55:22:01:04:66 11:30:45, 11 Jul. ARP [del] br0 192.168.1.68 fa:55:22:01:04:66 11:28:13, 11 Jul. DHCP device Connected: 192.168.1.68, fa:55:22:01:04:66, unknown 11:28:13, 11 Jul. LAN [ADD] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0(wl1) 11:28:13, 11 Jul. ARP [add] br0(wl1) 192.168.1.68 fa:55:22:01:04:66 11:27:41, 11 Jul. DHCP device Disconnected: 192.168.1.68, fa:55:22:01:04:66, unknown 11:27:41, 11 Jul. LAN [DEL] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0 11:27:37, 11 Jul. ARP [del] br0 192.168.1.68 fa:55:22:01:04:66 11:26:25, 11 Jul. DHCP device Connected: 192.168.1.68, fa:55:22:01:04:66, unknown 11:26:25, 11 Jul. LAN [ADD] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0(wl1) 11:26:25, 11 Jul. ARP [add] br0(wl1) 192.168.1.68 fa:55:22:01:04:66 11:25:52, 11 Jul. DHCP device Disconnected: 192.168.1.68, fa:55:22:01:04:66, unknown 11:25:52, 11 Jul. LAN [DEL] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0 11:25:48, 11 Jul. ARP [del] br0 192.168.1.68 fa:55:22:01:04:66 11:25:11, 11 Jul. ARP [add] br0(wl1) 192.168.1.68 fa:55:22:01:04:66 11:25:10, 11 Jul. ARP [del] br0 192.168.1.68 fa:55:22:01:04:66 11:19:05, 11 Jul. ARP [add] br0(wl1) 192.168.1.68 fa:55:22:01:04:66 11:18:41, 11 Jul. DHCP device Connected: 192.168.1.68, fa:55:22:01:04:66, unknown 11:18:41, 11 Jul. LAN [ADD] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0(wl1) 11:18:39, 11 Jul. 2.4G Client associate from fa:55:22:01:04:66 (IP=192.168.1.68) RSSI=-79, Rate=130Mbps, host 11:18:39, 11 Jul. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT 11:18:39, 11 Jul. Receive a DHCP request 11:18:10, 11 Jul. ARP [add] br0(wl0) 192.168.1.68 fa:55:22:01:04:66 11:18:10, 11 Jul. ARP [del] br0 192.168.1.68 fa:55:22:01:04:66 11:17:31, 11 Jul. ARP [del] br0 192.168.1.115 a0:78:17:7b:2f:4c 11:17:02, 11 Jul. DHCP device Disconnected: 192.168.1.115, a0:78:17:7b:2f:4c, MacBook-Pro-2 11:17:01, 11 Jul. LAN [DEL] ARP 192.168.1.115 with a0:78:17:7b:2f:4c from br0 11:16:22, 11 Jul. ARP [add] br0(wl0) 192.168.1.68 fa:55:22:01:04:66 11:16:09, 11 Jul. 2.4G client Mac: FA:55:22:01:04:66 Deauthentications (Reason:Deauthenticated because sending station is leaving (or has left) IBSS or ESS) 11:16:03, 11 Jul. DHCP device Connected: 192.168.1.68, fa:55:22:01:04:66, unknown 11:16:03, 11 Jul. LAN [ADD] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0(wl0) 11:16:02, 11 Jul. Self roaming might be occurring... Deauth original one... 11:13:22, 11 Jul. ARP [add] br0(wl1) 192.168.1.68 fa:55:22:01:04:66 11:13:15, 11 Jul. DHCP device Connected: 192.168.1.68, fa:55:22:01:04:66, unknown 11:13:15, 11 Jul. DHCP lease issued 192.168.1.68 to fa:55:22:01:04:66 , lease duration is 86400 seconds 11:13:15, 11 Jul. 2.4G Client associate from fa:55:22:01:04:66 (IP=192.168.1.68) RSSI=-69, Rate=78Mbps, host 11:13:15, 11 Jul. LAN [ADD] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0(wl1) 11:13:15, 11 Jul. Receive a DHCP request 11:13:14, 11 Jul. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT 10:41:26, 11 Jul. 2.4G client Mac: FA:55:22:01:04:66 Deauthentications (Reason:Disassociated due to inactivity ) 10:39:47, 11 Jul. ARP [del] br0 192.168.1.68 fa:55:22:01:04:66 10:39:31, 11 Jul. LAN [DEL] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0 10:39:27, 11 Jul. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT 10:24:41, 11 Jul. ARP [add] br0(wl1) 192.168.1.68 fa:55:22:01:04:66 10:24:35, 11 Jul. DHCP device Connected: 192.168.1.68, fa:55:22:01:04:66, unknown 10:24:35, 11 Jul. 2.4G Client associate from fa:55:22:01:04:66 (IP=192.168.1.68) RSSI=-81, Rate=117Mbps, host 10:24:35, 11 Jul. LAN [ADD] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0(wl1) 10:24:34, 11 Jul. Receive a DHCP request 10:24:33, 11 Jul. Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT 10:19:22, 11 Jul. ARP [del] br0 192.168.1.68 fa:55:22:01:04:66 10:19:07, 11 Jul. DHCP device Disconnected: 192.168.1.68, fa:55:22:01:04:66, unknown 10:19:07, 11 Jul. LAN [DEL] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0 10:18:08, 11 Jul. 2.4G client Mac: 16:F6:09:E1:79:B8 Deauthentications (Reason:Disassociated due to inactivity ) 10:17:52, 11 Jul. DHCP device Connected: 192.168.1.68, fa:55:22:01:04:66, unknown 10:17:52, 11 Jul. LAN [ADD] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0(wl1) 10:17:52, 11 Jul. ARP [add] br0(wl1) 192.168.1.68 fa:55:22:01:04:66 10:17:52, 11 Jul. DHCP device Disconnected: 192.168.1.68, fa:55:22:01:04:66, unknown 10:17:52, 11 Jul. LAN [DEL] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0 10:17:47, 11 Jul. ARP [del] br0 192.168.1.68 fa:55:22:01:04:66 10:16:33, 11 Jul. DHCP device Disconnected: 192.168.1.195, 16:f6:09:e1:79:b8, unknown 10:16:32, 11 Jul. LAN [DEL] ARP 192.168.1.195 with 16:f6:09:e1:79:b8 from br0 10:16:28, 11 Jul. ARP [del] br0 192.168.1.195 16:f6:09:e1:79:b8 10:13:20, 11 Jul. ARP [add] br0(wl1) 192.168.1.68 fa:55:22:01:04:66 10:13:18, 11 Jul. ARP [del] br0 192.168.1.68 fa:55:22:01:04:66 10:12:36, 11 Jul. DHCP device Connected: 192.168.1.68, fa:55:22:01:04:66, unknown 10:12:36, 11 Jul. LAN [ADD] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0(wl1) 10:12:35, 11 Jul. ARP [add] br0(wl1) 192.168.1.68 fa:55:22:01:04:66 10:10:51, 11 Jul. DHCP device Disconnected: 192.168.1.68, fa:55:22:01:04:66, unknown 10:10:51, 11 Jul. LAN [DEL] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0 10:10:47, 11 Jul. ARP [del] br0 192.168.1.68 fa:55:22:01:04:66 10:10:04, 11 Jul. ARP [add] br0(wl1) 192.168.1.68 fa:55:22:01:04:66 10:10:02, 11 Jul. ARP [del] br0 192.168.1.68 fa:55:22:01:04:66 09:55:26, 11 Jul. DHCP device Connected: 192.168.1.68, fa:55:22:01:04:66, unknown 09:55:25, 11 Jul. LAN [ADD] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0(wl1) 09:55:25, 11 Jul. ARP [add] br0(wl1) 192.168.1.68 fa:55:22:01:04:66 09:55:22, 11 Jul. DHCP device Disconnected: 192.168.1.68, fa:55:22:01:04:66, unknown 09:55:22, 11 Jul. LAN [DEL] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0 09:55:18, 11 Jul. ARP [del] br0 192.168.1.68 fa:55:22:01:04:66 09:54:36, 11 Jul. ARP [add] br0(wl1) 192.168.1.68 fa:55:22:01:04:66 09:54:34, 11 Jul. ARP [del] br0 192.168.1.68 fa:55:22:01:04:66 09:51:49, 11 Jul. DHCP device Connected: 192.168.1.68, fa:55:22:01:04:66, unknown 09:51:49, 11 Jul. LAN [ADD] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0(wl1) 09:51:49, 11 Jul. ARP [add] br0(wl1) 192.168.1.68 fa:55:22:01:04:66 09:51:32, 11 Jul. DHCP device Disconnected: 192.168.1.68, fa:55:22:01:04:66, unknown 09:51:31, 11 Jul. LAN [DEL] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0 09:51:27, 11 Jul. ARP [del] br0 192.168.1.68 fa:55:22:01:04:66 09:49:43, 11 Jul. ARP [add] br0(wl1) 192.168.1.68 fa:55:22:01:04:66 09:49:37, 11 Jul. DHCP device Connected: 192.168.1.68, fa:55:22:01:04:66, unknown 09:49:36, 11 Jul. DHCP lease issued 192.168.1.68 to fa:55:22:01:04:66 , lease duration is 86400 seconds 09:49:36, 11 Jul. 2.4G Client associate from fa:55:22:01:04:66 (IP=192.168.1.68) RSSI=-81, Rate=117Mbps, host 09:49:36, 11 Jul. LAN [ADD] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0(wl1) 09:49:36, 11 Jul. Receive a DHCP request 09:19:42, 11 Jul. ARP [del] br0 192.168.1.68 fa:55:22:01:04:66 09:19:30, 11 Jul. LAN [DEL] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0 09:06:26, 11 Jul. DHCP device Connected: 192.168.1.68, fa:55:22:01:04:66, unknown 09:06:26, 11 Jul. LAN [ADD] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0(wl1) 09:06:26, 11 Jul. ARP [add] br0(wl1) 192.168.1.68 fa:55:22:01:04:66 09:06:17, 11 Jul. DHCP device Disconnected: 192.168.1.68, fa:55:22:01:04:66, unknown 09:06:17, 11 Jul. LAN [DEL] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0 09:06:13, 11 Jul. ARP [del] br0 192.168.1.68 fa:55:22:01:04:66 09:05:05, 11 Jul. ARP [add] br0(wl1) 192.168.1.68 fa:55:22:01:04:66 09:05:05, 11 Jul. ARP [del] br0 192.168.1.68 fa:55:22:01:04:66 09:04:31, 11 Jul. DHCP device Connected: 192.168.1.68, fa:55:22:01:04:66, unknown 09:04:30, 11 Jul. LAN [ADD] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0(wl1) 09:04:30, 11 Jul. ARP [add] br0(wl1) 192.168.1.68 fa:55:22:01:04:66 09:04:03, 11 Jul. DHCP device Disconnected: 192.168.1.68, fa:55:22:01:04:66, unknown 09:04:02, 11 Jul. LAN [DEL] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0 09:03:58, 11 Jul. ARP [del] br0 192.168.1.68 fa:55:22:01:04:66 09:03:17, 11 Jul. DHCP device Connected: 192.168.1.68, fa:55:22:01:04:66, unknown 09:03:17, 11 Jul. LAN [ADD] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0(wl1) 09:03:17, 11 Jul. ARP [add] br0(wl1) 192.168.1.68 fa:55:22:01:04:66 09:02:26, 11 Jul. DHCP device Disconnected: 192.168.1.68, fa:55:22:01:04:66, unknown 09:02:26, 11 Jul. LAN [DEL] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0 09:02:22, 11 Jul. ARP [del] br0 192.168.1.68 fa:55:22:01:04:66 09:01:01, 11 Jul. ARP [add] br0(wl1) 192.168.1.68 fa:55:22:01:04:66 09:00:59, 11 Jul. ARP [del] br0 192.168.1.68 fa:55:22:01:04:66 09:00:49, 11 Jul. 2.4G Client associate from fa:55:22:01:04:66 (IP=192.168.1.68) RSSI=-83, Rate=5Mbps, host 09:00:49, 11 Jul. Receive a DHCP request 09:00:48, 11 Jul. DHCP device Connected: 192.168.1.68, fa:55:22:01:04:66, unknown 09:00:48, 11 Jul. LAN [ADD] ARP 192.168.1.68 with fa:55:22:01:04:66 from br0(wl1) 09:00:03, 11 Jul. DoS(Port Scanning): IN=ppp0 OUT= MAC= src=74.218.29.74 DST=31.185.231.126 LEN=60 TOS=0x00 PREC=0x00 TTL=50 ID=21078 DF PROTO=TCP SPT=8283 DPT=29321 WINDOW=0 RES=0x00 URG ACK PSH RST SYN FIN URGP=62885 MARK=0x8000000 09:00:03, 11 Jul. DoS(Spoofing): IN=ppp0 OUT= MAC= src=74.218.29.74 DST=31.185.231.126 LEN=60 TOS=0x00 PREC=0x00 TTL=50 ID=21078 DF PROTO=TCP SPT=8283 DPT=29321 WINDOW=0 RES=0x00 URG ACK PSH RST SYN FIN URGP=62885 MARK=0x8000000 09:00:03, 11 Jul. DoS(Spoofing): IN=ppp0 OUT= MAC= src=74.218.29.74 DST=31.185.231.126 LEN=60 TOS=0x00 PREC=0x00 TTL=50 ID=21078 DF PROTO=TCP SPT=8283 DPT=29321 WINDOW=0 RES=0x00 URG ACK PSH RST SYN FIN URGP=62885 MARK=0x8000000
Tags (1)
Fixes: 374
@jwalowe76 That last post is unreadable. What we really need is a .csv file of it, attached to a post. To get that, click the 'Export' tab as in the picture below:
Tags (1)
