New to plusnet today , landline no longer working
- Full Fibre
- New to plusnet today , landline no longer working
16-03-2026 9:47 PM
Re: New to plusnet today , landline no longer working
16-03-2026 10:12 PM - edited 16-03-2026 10:16 PM
@Redmen1892 New BB installations have been for some time just that - no phone element - which you should have been advised about when you placed the order. I suspect, due to the way this happened, I doubt you will be able o recover the phone service over the PSTN network, but the number should be quarantined for 30 days after the installation, to enable you to arrange moving it to a VoIP service.
If this is actually a Full Fibre install, that service is definitely without a phone service - the line simply does not have any voice capability at all, and it is clearly advised as such online.
16-03-2026 10:20 PM
16-03-2026 10:25 PM
I would call support ASAP, but I have my doubts that you will be able to regress the install. I assume your M-I-L did not have an internet connection at all, previously?
16-03-2026 10:25 PM
16-03-2026 10:30 PM
16-03-2026 10:33 PM
You are correct - the PSTN network is currently scheduled to be totally switched off January 2027.
16-03-2026 10:34 PM
16-03-2026 11:00 PM
@Redmen1892 wrote:
Hi, due to family circumstances my wife needs to work from her elderly mothers house for the foreseeable future, prior to this morning all that there was at the property was a bit landline. We requested a full fibre 74 connection which was installed by the engineer today, but my mother in law has told us that her landline no longer works, have we missed something here as we required the existing landline to stay as is and just have a broadband connection so my wife could work from her home.
@Redmen1892 I don't know what may be possible but I have escalated your post on the offchance that something could be arranged within the BT group (different parts of the group offering different facilities).
Very much a longshot but worth a try. I'm guessing if there is any resulting modification of the set-up there might be a financial cost involved but from what you've said that might perhaps not be the primary consideration.
As I said, this is very much a longshot, but better to ask than not.
I'll post back with whatever I'm told is decided, in due course.
16-03-2026 11:05 PM
16-03-2026 11:09 PM
Apart from the cost of an ATA I would doubt that the cost of connecting the existing phone handset to VoIP would be any more expensive than the separate landline phone, depending on n the number of outgoing calls it could be considerably cheaprt.
To be honest I doubt a non technical elderly user would notice the difference.
The only difficulty that can creep in is if there’s any wired extensions or care alarms that use the PSTN.
16-03-2026 11:16 PM
@Redmen1892 wrote:
I've erroneously Left a 90 yo without a landline.
Can you leave them with a mobile phone?. If there’s no mobile signal then there are several cheap monthly contract mobile providers that support WiFi calling.
16-03-2026 11:16 PM
16-03-2026 11:19 PM
17-03-2026 7:08 AM - edited 17-03-2026 7:08 AM
We moved our landline to voip and use an app on the mobile to receive landline calls. Benefit if there is no mobile signal, is if the mobile supports wifi calling. No cost to transfer to my provider, but a £3.60 monthly fee.
Mark
- Full Fibre
