New to Fibre, first in my area, small bursts of packet loss weekday mornings only
- Full Fibre
- Re: New to Fibre, first in my area, small bursts o...
- « Previous
- 1
- 2
- Next »
Re: New to Fibre, first in my area, small bursts of packet loss weekday mornings only
4 hours ago
So far my wired testing showed a drop at 11pm and 4am overnight ruling out my mornings only theory.
So far as I can tell; it’s every site. It’s universal packet loss. Multiplayer is interrupted. Video calls. Pings to Google hosts and CloudFlare hosts.
4 hours ago - last edited 4 hours ago
Something seems afoot.
What speed FTTP are you on? I'm on 150Mbps FF and have tried pings to 1.1.1.1 from my Windows PC - which is connected to the Hub 2 by 5GHz Wi-Fi - and typically get a response time of 4/5ms with occasional longer times up to 11ms, with no packet loss (in a run of 100).
2 hours ago
@pvmb I'm on 300. I leave the pings running all day and night now; I noticed a 15 second drop ish at 11pm and 4am last night.
I just had another drop at 10:26am and now I have my think broadband monitor set up; it picked that up on the pings back to me also :
"2026-05-06T10:25:00+01:00","100","","5089000","5357000","5594000","1"
"2026-05-06T10:26:40+01:00","100","6","5070000","5376000","5951000","301"
"2026-05-06T10:28:20+01:00","100","","4638000","5376000","5572000","1"
I called PN yesterday explaining the issue on ethernet and video calls drop out for 15 seconds but the response I had on emails was about wifi signal, and response on phone suggested that engineers don't come out for packet loss.
There's bursts of packet loss at random times. No pattern I can see anymore. No disconnect. The packet loss in that time is severe (averaged out over a period it's not because the connection is 100% brilliant at all other times).
I'm lost. I mention @Dan_the_Van @markhawkin also since I've set up the monitor suggested.
I'll leave it running a week. But I feel like I'm out of options. it's a new Hub and the existing one was fine when I was FTTC. and I don't see any way of anyone checking the optical cable or kit without having to fork out big money
I'm just so sad because my FTTC connection was perfect and stable all day and night and now I've "upgraded" to this.
2 hours ago - last edited an hour ago
Sorry the thing wouldn't let me attach my image of the chart only the CSV, I try again showing the little red line where the first thing it picked up was showing, and again another spike because it usually happens more often in the mornings and so it happened again at 10:51
Edit to add: yep it shows 6%... but if it was 6% evenly over a minute I guess it would be ok. but it's like 15 seconds of 50% loss and that's enough to knock out all the video calls or any multiplayers
an hour ago
Might I suggest you share a 'live link' that way a real-time view of thinkbroadband graph is viewable to all.
No personal data is revealed.
44 minutes ago
28 minutes ago
@Dan_the_Van wrote:Might I suggest you share a 'live link' that way a real-time view of thinkbroadband graph is viewable to all.
I set up a DNS for my IP in case it floated.
It has a 3rd spike now, overnight there was only the 11pm and 4am issues but I had noticed I seemed to be being affected more in the mornings. I'm not home at the moment. Nobody is using the internet
25 minutes ago
@pvmb wrote:
Have you had a look at the Hub 2 Technical log entries around the times of these drops?
Nothing at all is logged when it happens. I had even disabled wifi completely to make sure it wasn't devices roaming causing a firmware blip.
It's just about 10-15 seconds of 50-80% packet loss... so averaging about 5-8% over 1 minute so it looks "small" but it bins off the video meets
10 minutes ago
@iZian just re-read through the thread...
Didnt see it noted , have you ever tried changing the cable between the ONT and router ? unlikley the cause but worth eliminating as a possible
- « Previous
- 1
- 2
- Next »
- Full Fibre
