New fibre install can i choose where master socket goes?
- Full Fibre
- Re: New fibre install can i choose where master so...
- « Previous
- 1
- 2
- Next »
Re: New fibre install can i choose where master socket goes?
01-11-2014 10:27 PM
There is no VDSL modem inside the hub 4 - unlike the hub 5.
You would still need the modem that the engineer will bring to connect it up.
If you want an all in one like me, I suggest you purchase a BT hub 5 which has an integrated VDSL modem so no need for the modem that the engineer will bring (meaning you only need 1 power socket)
NE
NE
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up
Message 16 of 24
(2,265 Views)
02-11-2014 7:43 AM
oh yeah silly me
i got it new for £10 off a facebook selling site mainly so i have a spare i may look out for a home hub 5 or something else with vdsl in.
Message 17 of 24
(2,265 Views)
02-11-2014 2:13 PM
I have a few BT hub 5's.
I'll be able to post and send me an offer via PM.
NE
NE
Message 18 of 24
(2,265 Views)
03-11-2014 7:26 PM
cheers will think about it, its all installed now in hall way but tp link home plug is performing well so not too bothered and getting good speed via homeplug at moment.
http://www.speedtest.net/my-result/3881129838
Message 19 of 24
(2,265 Views)
03-11-2014 7:45 PM
That's better than my BT infinity 2 speed!
I get 52mb through direct 1GB ethernet cable
Message 20 of 24
(2,265 Views)
03-11-2014 8:08 PM
yeah its not bad as its through a powerline adapter i did plug in direct to router and it wasnt hardly any different within a few meg and the ping was 5 rather than 11 which I can live with. Just done another test and it's around the same so hope it stays like that or gets faster,
http://www.speedtest.net/my-result/3881241021
Message 21 of 24
(2,265 Views)
03-11-2014 8:36 PM
It may gradually get faster - depending on your line.
Just don't turn off the white open reach modem or the router.
NE
NE
Message 22 of 24
(2,265 Views)
03-11-2014 8:48 PM
ive switched off the router a few times thats not a problem as long as i dont turn off the openreach modem thats one of the good things about having that set up as the modem stays in sync.
Message 23 of 24
(2,265 Views)
03-11-2014 9:13 PM
That's not too bad.
The only thing with the OR modem is you can't see your logs of your FTTC connection - but mine is hacked.
/NE
/NE
Message 24 of 24
(2,265 Views)
- « Previous
- 1
- 2
- Next »
- Full Fibre
