New Full Fibre customer - help, advice needed please
jadownet
Hoping someone can provide some help/clarification.
Was told full fibre was activated on Wednesday, since then haven't been able to use it.
Phoned up customer services who referred me to tech team and the chap on the phone said it may have been an ONT mismatch so he apparently referred to fault team.
I then had a phone call from tech team who said apparently everything is ok on their side and they don't know what the issue is so will send an engineer out on Friday.
Spent all day waiting for the engineer to arrive then decided to ring up and was told that for some reason the engineer appointment was cancelled and would have to rebook for Monday.
So i'm trying to figure out exactly what is happening, is there a mismatch on the ONT or is the router provided faulty?
Im hoping someone can provide details and also check that the appointment hasn't been cancelled again.
Many Thanks,
16 REPLIES 16
Fixes: 531
Re: New Full Fibre customer - help, advice needed please
@jadownet  let's start with something basic,  What's the status of the lights on the ONT  ?
jadownet
Thanks for the quick reply @MisterW
The Power, ‘PON’ & ‘LAN’ lights on the ONT are currently on.
Fixes: 531
That's good, it means the physical fibre connection is intact. What's the status & colour of the light on the router ? ( I assume its a Hub 2 ?)
jadownet
It is a Hub2.
The light is non flashing orange.
Fixes: 531
I'm afraid that does sound like a fibre circuit routing issue, the Hub can't establish a connection. Did the engineer not check it was working when it was installed ?
jadownet
Thanks,
The property is actually a new build and we are the first owners, we only moved in last week so we weren’t around when OpenReach did the works.
Fixes: 531
So the ONT was pre installed ?
In which case is very possible that Openreach's records are wrong and there is an ONT mismatch. It will need an Openreach engineer to physically check the ONT serial number and get the circuit correctly configured for that ONT
jadownet
Yes that is correct.
The ONT was already pre-installed and switched on when we moved in.
Fixes: 531
In that case I'm afraid it's wait for an Openreach engineer. I've seen at least one other case where the wrong serial numbers have been recorded for preinstalled ONTs. Seems the only way to get the correct one into the system is for an engineer to physically see it!!
jadownet
Ok thanks for your help!
Can I just check my appointment is still booked for Monday between 8 and 1pm?
An engineer was meant to come yesterday but for some reason no one told me that they cancelled until I rang you guys and I’m a bit nervous that it will get cancelled again without me being told.
Fixes: 531
I'm not staff, so have no access to your account. You can either call customer services or wat for one of tge staff who monitor these forums ( but they are often thin on the ground at the w/e )
Bear in mind that Openreach engineers are in a series of strikes at the moment so appointments do seem to be getting cancelled at short notice,
jadownet
Will wait for someone to check for me if they are around.
In regards to engineers striking I didn’t realise they were also striking as well is there a website as I’ve done a quick Google but couldn’t find anything up to date.
willcutforth
Fixes: 113
Hey there @jadownet I can confirm that there is an engineer booked for Monday and as of yet nothing has changed. You can check on the CWU website which is the union for Openreach and Royal Mail.
 Will Cutforth
Fixes: 531
@willcutforth thanks for picking this up
