New Customer
Fixes: 382
Re: New Customer
@tyga2025 - prove it - using authoritative links.
tyga2025
Re: New Customer
Google it , If you do not want to accept that , that is your prerogative.
I don't care if you don't want to believe I'm right.
But I do have the correct information
Fixes: 382
Re: New Customer
You made the incorrect assertion - you prove it!
Fixes: 147
Re: New Customer
Where as Part Fibre (FTTC copper last mile) would use DLM I can't see why Full Fibre would.
 EDIT: removed incorrect link
New link: - what replaces DLM for Full Fibre
Fixes: 382
Re: New Customer
Thanks @Dan_the_Van . Thought that link to 'Gemini' - whatever it is - looked a tad 'suspicious' - 'created today' made it look funny.
tyga2025
Re: New Customer
Yes your correct but what your not listening to is Plusnet is still using Openreach Old infrastructure that was created for copper wire services.
Your getting Full Fibre connection to your poperty but it is controlled through Openreach Old infrastructure that Plusnet are using. They set up a profile for every customer through Openreach Old infrastructure.
tyga2025
Re: New Customer
Why ? I given you facts , I told you contact there IT . If you don't want to fine. I couldn't care less
Fixes: 382
Re: New Customer
What in Hells name is that???!!!!
Fixes: 382
Re: New Customer
You have not given 'facts', just some wild claims with no proof!
Fixes: 147
Re: New Customer
So its Profile management, nothing to do which copper line performance which is what DLM is for.
Fixes: 579
Re: New Customer
ALL ISP's , including the Altnets, have a profile associated with each Fibre connection. That's how they can offer a customer different throughput speeds at different prices, and manage the network capacity
tyga2025
Re: New Customer
Yes . I'm not disagreeing with you or other people here. but you still seem to think that Plusnet is not using Openreach Old infrastructure for copper wire services.
Your obviously not that updated on Plusnet infrastructure
Fixes: 579
Re: New Customer
but the same infrastructure is used by all ISPs that supply FTTP via Openreach, PLusnet is no different!
Fixes: 382
Re: New Customer
Ah - we are getting somewhere. Of course ADSL/FTTC services stil run on the 'copper' network - BUT FTTP(Full Fibre) doesn't.
@tyga2025 What is your experience in the comms industry?
