Network Discovery
norster
Network Discovery
I have just upgraded form FTTC to FTTP, and now have the Plusnet Hub 2 router.
Since upgrading, when looking in Network within File Explorer, I can no longer see any other PC, laptop or NAS on my network. Most of the time, I cannot even see my own PC.
Is this a known issue, or has something changed by changing router ?
8 REPLIES 8
Browni
Aspiring Hero
Fixes: 61
Re: Network Discovery
You need to change your network type to private.
norster
Thanks, Browni.
I've tried that, and can see my PC all the time now, others are appearing slowly.
Forgive my naivity.
Browni
Aspiring Hero
Fixes: 61
The only thing I can think of is to restart your router.
When windows connects to a new network it will default to Public, so ALL windows devices on your network will need changing to Private
Dan
Edit- tidy up post
norster
Thank you, Dan.
I've just switched on a laptop that hadn't connected to this router before, and it can see all the devices on my network, but it is set to Public, not Private.
norster
In fact, I've just flipped my PC back to Public, and I can still them all.
Just needed to flip the Network Discovery, as it said each time I changed network type, that Network Discovery was Off, so set to On, and seems to have worked ?
Browni
Aspiring Hero
Fixes: 61
I thought you couldn't see all devices on your PC?
Changing the network to private should enable network discovery.
norster
I flipped from Public to Private, and could see most of my devices - I can't see my printer as I used to.
I then flipped back to Public, and could still see them.
I then re-booted, and had to flip back to Private to see them again.
Thank you all - setting to Private seems to be the answer, except I cannot see my printer any more.
