Moving a ONT box
minkey
Moving a ONT box
Hi.
I have full fibre and would like to know if there a procedure for moving my ONT to a different location?
We are looking to get a house extension which would mean the wall where the fibre enters the house will be demolished, so would like the ONT moved to a different room.
I assume this would require an engineer visit and is a chargeable event?
Does anyone or PlusNet staff know the process for this?
Thanks in advance
7 REPLIES 7
Fixes: 72
Re: Moving a ONT box
@minkey
Phone PN and ask for them to arrange a visit. I believe the current cost is £160.
If you're getting work done, consider putting in ethernet cables at the same time to help with distributing the internet signal around the house.
Fixes: 444
@minkey
Is it just the ONT? If you are removing an exterior wall is there an external CSP box that will also need moving?
Fixes: 72
@minkey
I've just checked - this appears to be one of those occasions you can contact OR direct. See
https://www.openreach.com/building-developers-and-projects/altering-our-network/for-consumer-and-bus...
minkey
@Baldrick1 - The CSP box location is not changing. There currently a black wire which comes from that and snakes around my house to where it enters the to be affected room  through the wall into a small white disc and then it goes to the ONT. To my mind, it should be a fairly straightforward move.
@bmc  - Thanks for the link. That may be an easier route than going through PN.
mystreet1
Or you could DIY the move.
Example of how to
https://www.premitel.uk/consultancy/expert-advice/how-to-move-the-fttp-ont/
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
Fixes: 444
This like a very simple solution providing there's a wall to which the coupler box can be fixed. But if the wall is to be demolished....
Please,no connectors under the floor,
Fixes: 72
@minkey
I assume you got a satisfactory reply from OpenReach.
