MTU Setting
Staro
Re: MTU Setting
Staro
Re: MTU Setting
More Info:
At first I thought it must be a PS Network issue, rang Plusnet customer service last week and the nice lady said there was nothing they could do and it may be a software fault on Sony's side to which I thought more than likely. After getting in contact with Sony the advice given was to open certain ports on my router, I've never had to do this before on any isp or modem/router but I did anyway and again it did not resolve the problem. It was only until I took my PS Vita to my mate's house on Friday that I realised maybe it's not a PSN issue as it worked without error. Differences being, Router, Service Provider and ADSL2 instead of Fibre. I should be able to check it on Thursday on a Plusnet Business connection, narrowing it down to only router and connection type.
Moderator's note by Adie (Dvorak) edited for readability as it was flowing off screen.
npr
Fixes: 9
Re: MTU Setting
Edit: Seriously how do I quote, the tag thing is working but prefer to quote.
Highlight and copy what you want to quote.
In reply click the "insert code" icon, past quote in that window.
No, that's not right Undecided
Browni
Aspiring Hero
Fixes: 61
Re: MTU Setting
@Staro wrote:
Click Reply under the post you want to quote and then click the Quote button when the reply appears for typing.
Staro
Re: MTU Setting
Ah it was there from the start, all dark greyed out instead of pink !
Moderator's note by Adie (Dvorak): Full quote of preceding post removed as per the forum rules
Re: MTU Setting
@Staro wrote:
Not necessarily, 1492 is just the typical maximum MTU of other routers when connecting to an external modem using the PPPoE protocol.
My current router has the ability to set the router MTU to 1508 so that the PPPoE link to the modem can take the full 1500 ethernet packet size.  But at the same time I'm also running an IPv6 tunnel on the same connection and that has an MTU of 1472 and works perfectly.  So don't get hung up on wanting 1492, it's just a number, and probably not a very optimum one either.
As @npr alluded to, if the router is fixed at 1488 then don't worry about it, but try finding an equal or lower MTU for the PS which makes the error you are seeing go away.
Staro
Re: MTU Setting
I'm not super technical, just a tid bit. I can follow what you tell me Smiley unless you get super duper Crazy technical then I'll have to ask.
I have no idea what the number 1492 represents, I just want a number that allows me to play online if possible without disconnects
1500 or anything down to 1400 via the PS (took ages to set manually and reboot btw Wink) didn't clear it.
npr
Fixes: 9
Re: MTU Setting
Agreed. Thumbs_Up
I'm having the following error over the Playstation Network "The router in use may not support IP Fragments..."
Does it say this is a error message?
Looks more like a information message which IMO can be safely ignored.
Staro
Re: MTU Setting
I would definitely ignore it if I could get online Wink
It's an internet/network settings test message that also fails to result the dl/ul speed which never did previously.
Only came across it after failing to connect to certain online games. (Can connect to the PSN no problems)
npr
Fixes: 9
Re: MTU Setting
Could it be the game server is down?
I'm not familiar with the PS, but can you connect to other sites?
Is this any help:
http://www.dualshockers.com/2014/12/29/ps4s-temporary-mtu-1473-fix-to-access-the-psn-made-official-b...
Anyone else having problems making posts?
Every 2nd or 3rd post is failing with "Secure Connection Failed", may be this end as I've been DLM'd with g.inp removed.
Staro
Re: MTU Setting
May help someone reading to help me...I have no idea, I  just read the internet;
« SpeedGuide.net TCP Analyzer Results »
Tested on: 2016.05.01 17:05
IP address: 87.112.xxx.xxx
Client OS/browser: Windows 10 (Firefox 45.0)
TCP options string: 020405a80103030801010402
MSS: 1448
MTU: 1488
TCP Window: 66560 (NOT multiple of MSS)
RWIN Scaling: 8 bits (2^8=256)
Unscaled RWIN : 260
Recommended RWINs: 63712, 127424, 254848, 509696, 1019392
BDP limit (200ms): 2662kbps (333KBytes/s)
BDP limit (500ms): 1065kbps (133KBytes/s)
MTU Discovery: ON
TTL: 51
Timestamps: OFF
SACKs: ON
IP ToS: 10000000 (128)
Precedence: 100 (flash override)
Delay: 0 (normal delay)
Throughput: 0 (normal throughput)
Reliability: 0 (normal reliability)
Cost: 0 (normal cost)
Check bit: 0 (correct)
DSCP (DiffServ): CS4 100000 (32) - class 4 (RFC 2474). Similar forwarding behavior to the ToS Precedence field.
npr
Fixes: 9
Re: MTU Setting
Don't see any problems there.
Although I assume that's from a PC not the PS.
Staro
Re: MTU Setting
Is this any help:
Nah won't be PSN, had trouble for at least 2 weeks that I know of (maybe since I joined), I'm a newbie Smiley only been with PN for 4 weeks and even still the customer service is outstanding, lovely people on the phone.
I had trouble this week with NDT and NSC but since OR engineer came out Friday all been fine, was on PH yesterday morning with no problems Embarrassed
Re: MTU Setting
I've not had any trouble here, other than the new forum being slow and clunky.
However, @jaread83 is collecting evidence of "Secure Connection Failed" in this topic -
Authentication error on community - are you affected?
if you could leave some screen shots there, along with which OS and what browser version  Wink
Staro
Re: MTU Setting
Yeah from PC, not PS.
Maybe PS doesn't like 1488 ?
Wondering if buying a modem/router with the ability to save MTU to 1492 will resolve my issue, I don't mind buying it but man am I having a hard time deciding on one that hasn't been discontinued and difficult to get hold of.
Settled on either Asus DSL-56U, Netgear D6400 or TP-Link Archer VR900 but wasn't sold on any of them Sad
