MAC Address Filtering - Can't find it ...
- Full Fibre
- MAC Address Filtering - Can't find it ...
- « Previous
- 1
- 2
- Next »
Re: MAC Address Filtering - Can't find it ...
26-04-2015 12:19 PM
I currently have a Netgear DGND3000 set up with MAC filtering and each device we connect has its IP assigned. I don't want to plug it in yet, in case it needs to go back but I cannot see anywhere in the links under Plusnet 2704n help http://www.plus.net/support/routerguidelinks/routerhelp/ ; to achieve the basic settings I mentioned.
The only option I see is to return this one and get a proper router or router/modem (DGND3700 or DGND4000?)
26-04-2015 12:58 PM
26-04-2015 1:08 PM
What do people use instead? Any recommendations :
26-04-2015 1:17 PM
26-04-2015 1:32 PM
Still, there should be some response from Plusnet with a firmware update to their router (or some other solution if that's not possible).
MAC filtering is such a useful and basic security setting,
29-04-2015 1:27 PM
You will find them here: http://192.168.1.254/expert_user.html
You need to log in with the usual router password.
I was going to change the router password but read of some people having issues so I won't bother for now. Check the Hardware section in the forum and you'll find more geeky details
29-04-2015 2:49 PM
A hard to guess WPA password provides real security, MAC filtering provides a false sense of it.
29-04-2015 3:06 PM
29-04-2015 3:19 PM
The more layers the more difficult to break in
29-04-2015 4:42 PM
Quote from: GR4CE I doubt there is a single method to keep any connection safe, really.
...but there is, it's called WPA2 with a sufficiently long password
01-04-2017 5:34 PM
Looking at Advanced Settings, it appears to my layman's eye that the router still does not support Mac filtering. Is that correct? Does Plusnet have any plans for an upgrade that does support this?
- « Previous
- 1
- 2
- Next »
- Full Fibre
