MAC Address Filtering - Can't find it ...
GR4CE
Re: MAC Address Filtering - Can't find it ...
I am waiting for Openreach to come install fibre on Tuesday and reading about the router that I received (Sagecom 2704n) I see that it is completely substandard (to put it mildly), and Plusnet even charges for it Sad
I currently have a Netgear DGND3000 set up with MAC filtering and each device we connect has its  IP assigned.  I don't want to plug it in yet, in case it needs to go back but I cannot see anywhere in the  links under Plusnet 2704n help http://www.plus.net/support/routerguidelinks/routerhelp/ ; to achieve the basic settings I mentioned.
The only option I see is to return this one and get a proper router or router/modem (DGND3700 or DGND4000?)
pwatson
The Netgear products you mention are all ADSL routers and they're not suitable for use with (or indeed without) the BT modem that will be supplied when your fibre service is installed.
GR4CE
hmm reading the description here http://www.netgear.co.uk/home/products/networking/dsl-modems-routers/dgnd4000.aspx it looked like this one would have worked (I'm not an expert as you can tell Cheesy )
What do people use instead? Any recommendations :
pwatson
Oops - Apologies.  Yes, the 4000 has ethernet WAN as well as an integrated ADSL modem so will work  Embarrassed
GR4CE
Smiley
Still, there should be some response from Plusnet with a firmware update to their router (or some other solution if that's not possible).
MAC filtering is such a useful and basic security setting,
GR4CE
@slovell  and for everybody's reference, I found more advanced settings and the MAC filtering options in the  Sagemcom 2704N supplied by Plusnet.
You will find them here: http://192.168.1.254/expert_user.html
You need to log in with the usual router password.
I was going to change the router password but read of some people having issues so I won't bother for now. Check the Hardware section in the forum and you'll find more geeky details Smiley
benfranklin
Just to play Devil's Advocate here, MAC filtering is next to useless.
A hard to guess WPA password provides real security, MAC filtering provides a false sense of it.
jelv
Fixes: 10
Both together are stronger than each on their own!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
GR4CE
I doubt there is a single method to keep any connection safe, really.
The more layers the more difficult to break in Smiley
benfranklin
Quote from: GR4CE
...but there is, it's called WPA2 with a sufficiently long password  Wink
duncan8leach
Looking at Advanced Settings, it appears to my layman's eye that the router still does not support Mac filtering.  Is that correct?  Does Plusnet have any plans for an upgrade that does support this?
