LOS red light on ONT
geoffday67
Had this tonight and therefore no internet. Texting the bot says there's a fault and I need an engineer visit, but that won't be for 2 days. Anyone got any thoughts how I might get this fixed quicker?
I'm not surprised it's failed tbh, I have zero faith in the installer. He was complaining how difficult it was to strip fibre cable without breaking it - did he not have a proper fibre stripper tool? He drilled my wall from the inside so broke a chunk of brick off as the drill broke through which I now have to repair. He put the screws holding the ONT directly into the wall without wall plugs so they are loose and the box is wobbling. He left the router in "setup" mode, I had to do a lot of googling to learn I had to put my own username/password in.
22 REPLIES 22
Fixes: 109
Re: LOS red light on ONT
@geoffday67
Can't help with the loss of service but you can file a report with OpenReach about the quality if the install. The form is on their website somewhere.
Installers always drill from the inside to out. It sounds as though they may have forgotten to turn off the hammer function on the drill before they got close to the external wall.
outcast
Aspiring Champion
Fixes: 19
@bmc wrote:
... you can file a report with OpenReach about the quality if the install. The form is on their website somewhere.
Probably this - https://www.openreach.com/help-and-support/damage-health-and-safety
Fixes: 569
@geoffday67
Other have answered regarding quality of the install but to answer the remaining...
It requires an Openreach engineer and so will be subject to their standard SLA for fault investigation
That's normal, the router should autoconfigure with the correct credentials. Also the installation engineer is an Openreach contractor and has no access to your username details.
Fixes: 109
@geoffday67
Hope you're not based in Scotland.
OR engineers could well be re-assigned to deal with the storm damage.
geoffday67
Thanks for the info, but I had to enter my password as part of my credentials. Does that mean that Plusnet also has access to my password?
When I rang support recently I was asked for letters from my password which suggests again that Plusnet store my password in non-hashed form.
Tags (1)
Fixes: 374
@geoffday67 Your password is stored by PN , otherwise how would they validate a login by you?
It is stored in hashed form - when support ask for characters from you password, only those being requested are displayed on the agents screen.
geoffday67
Thanks, but if it's hashed then the original password can't be extracted in order to see certain letters, or to send remotely to my router.
When I enter my password on the website, the web site hashes it and sends the hashed version to PN which compares it to the hashed password in their database. So the plain version is never stored. That's my understanding of normal practice. So if there is a hack then only the hashed passwords can be stolen in the worst case.
Fixes: 374
You will never know, because for obvious reasons, PN will never  reveal their security protocols.
geoffday67
I know what you mean, but the fact that they can see letters from my password and supply my password to my router shows that they are storing my password un-hashed iiuc.
Fixes: 374
If they are, do you not think that there wouldn't be countless PN accounts hacked?
geoffday67
I'm definitely not a security expert and I'm sure that a big company like PN would have robust security as you say. Still, there's a question to be answered, how they are able to access my password.
Fixes: 374
Which you won't get an answer to, as that could compromise their security protocols.
Ian06
Fixes: 6
I am not a security expert either, but they must store the pw encrypted so that they can be programmatically decrypted to check and distribute to the router.
You would assume a user interface for CS will prompt for some of the letters from your password and validate them against the pw that is stored encrypted...  they must use 2-way encryption to be able to do this and not a 1-way hash that could only be used to check the whole password...  it would obviously be much less secure if you needed to given your whole password over the phone to someone.
I doubt anyone will give a proper explanation of how it works and how they store password - for security reasons.
geoffday67
That's my point, passwords are stored in a decryptable format. Is that allowed? How secure is the decryption process? Sure I wouldn't expect PN to give me any details, and I don't lose sleep over it. But if there's a data breach like the co-op etc then someone will get a decryptable password list at best, maybe the decryption key too or whatever they use at worst.
