LOS red light on ONT
- Full Fibre
- Re: LOS red light on ONT
04-08-2025 10:05 PM
Had this tonight and therefore no internet. Texting the bot says there's a fault and I need an engineer visit, but that won't be for 2 days. Anyone got any thoughts how I might get this fixed quicker?
I'm not surprised it's failed tbh, I have zero faith in the installer. He was complaining how difficult it was to strip fibre cable without breaking it - did he not have a proper fibre stripper tool? He drilled my wall from the inside so broke a chunk of brick off as the drill broke through which I now have to repair. He put the screws holding the ONT directly into the wall without wall plugs so they are loose and the box is wobbling. He left the router in "setup" mode, I had to do a lot of googling to learn I had to put my own username/password in.
04-08-2025 10:13 PM
Can't help with the loss of service but you can file a report with OpenReach about the quality if the install. The form is on their website somewhere.
Installers always drill from the inside to out. It sounds as though they may have forgotten to turn off the hammer function on the drill before they got close to the external wall.
04-08-2025 10:42 PM
@bmc wrote:
... you can file a report with OpenReach about the quality if the install. The form is on their website somewhere.
Probably this - https://www.openreach.com/help-and-support/damage-health-and-safety
05-08-2025 6:46 AM
Other have answered regarding quality of the install but to answer the remaining...
It requires an Openreach engineer and so will be subject to their standard SLA for fault investigation
That's normal, the router should autoconfigure with the correct credentials. Also the installation engineer is an Openreach contractor and has no access to your username details.
05-08-2025 9:22 AM
Hope you're not based in Scotland.
OR engineers could well be re-assigned to deal with the storm damage.
05-08-2025 10:11 AM
When I rang support recently I was asked for letters from my password which suggests again that Plusnet store my password in non-hashed form.
05-08-2025 10:42 AM
@geoffday67 Your password is stored by PN , otherwise how would they validate a login by you?
It is stored in hashed form - when support ask for characters from you password, only those being requested are displayed on the agents screen.
05-08-2025 10:48 AM
When I enter my password on the website, the web site hashes it and sends the hashed version to PN which compares it to the hashed password in their database. So the plain version is never stored. That's my understanding of normal practice. So if there is a hack then only the hashed passwords can be stolen in the worst case.
05-08-2025 11:01 AM
You will never know, because for obvious reasons, PN will never reveal their security protocols.
05-08-2025 11:04 AM
05-08-2025 11:07 AM
If they are, do you not think that there wouldn't be countless PN accounts hacked?
05-08-2025 11:14 AM
05-08-2025 11:16 AM
Which you won't get an answer to, as that could compromise their security protocols.
05-08-2025 11:22 AM
@geoffday67 wrote:
I'm sure that a big company like PN would have robust security as you say. Still, there's a question to be answered, how they are able to access my password.
I am not a security expert either, but they must store the pw encrypted so that they can be programmatically decrypted to check and distribute to the router.
You would assume a user interface for CS will prompt for some of the letters from your password and validate them against the pw that is stored encrypted... they must use 2-way encryption to be able to do this and not a 1-way hash that could only be used to check the whole password... it would obviously be much less secure if you needed to given your whole password over the phone to someone.
I doubt anyone will give a proper explanation of how it works and how they store password - for security reasons.
05-08-2025 11:33 AM
