Joining the FTTP craze
RobPN
Fixes: 15
Re: Joining the FTTP craze
What you need @Alex is a faster method of painting, then you can get on with the important things in life like getting FTTP sorted. Wink
https://www.youtube.com/watch?v=EiZoSuNej5U
Alex
Fixes: 13
Thanks all,
Also my current Samsung TV which is being moved over and into my bedroom has a Satellite dish input. I assume I can get Freesat then? There is a dish feed in the room which is handy so I will certaintly may as well plug it in and try it.
So my priorities are:
1. Set up faster internet, make use of the FTTP if possible?
2. Set up TV with hopefully Freesat.
Way down on the list, is:
9,999,999. Colour of the walls.
Strat
Fixes: 565
@Alex I have a Hisense tv with a satellite socket (bnc) but it doesn't have Freesat software.
Your TV being a Samsung, probably does has Freesat built in. Thumbs_Up
RealAleMadrid
Fixes: 68
@Alex You and others have hijacked this thread with irrelevant posts, it looks like the OP @Timalay has given up on it.
Timalay
No, I'm just letting people get on with it.
RealAleMadrid
Fixes: 68
@Timalay You still haven't posted the BT Wholesale Checker result, that would confirm that Plusnet FTTP is available.
Timalay
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install Process
WBC FTTP Upto 1000 Upto 220 -- Available 1 Stage
RealAleMadrid
Fixes: 68
@Timalay That's settled it, you have Openreach FTTP available.
Timalay
Fair enough.
Alex
Fixes: 13
The OP was excited about the prospect of getting FTTP, as I am too. I don't see how that is 'hijacking' the thread with 'irrelevant' posts?
It is being rolled out to quite a few places locally here too and I was just pointing that out really. It just seems to be catching on now. Looking at the thread subject I feel my post was relevant.
That is all I was trying to say.
