Issue installing my full fibre - timescales?
Mouse25
Hello. I had full fibre installation booked for today. It was a 'trusted partner' of Open Reach that came and he immediately told me that he could not install as apparently fibre in my street is at the back and from overhead cables, and he'd need scaffolding to do the job.
I've already been reading through the forum and so did a property search. I can see I am in a FTTP priority area and FTTP install process is 1 stage but it also says 'Single Dwelling Unit Residential OH Feed alternate L2C solution required', so not sure why a 'normal' engineer was even sent in the first place as clearly there was always going to be a need for a specialist install.
I've already been waiting for weeks for broadband (I switched from another provider to PlusNet as they weren't even giving me an installation date and I urgently need connectivity) and the unknown extra time is triggering my anxiety disorder.
It would therefore be helpful to know if anyone else has been through this and, if so, how long it took.
Thank you,
7 REPLIES 7
Fixes: 357
Re: Issue installing my full fibre - timescales?
@Mouse25 Sadly, when you are an 'odd' case as you are, the system can get confused. All I can do is point a PN staffer in your direction - @Christopher_G  can you or one of your colleagues help here?
Christopher_G
Hi @Mouse25
I've sent you a private message to try and get you some help with this. Could you take a look at your community inbox and get back to me please?
Thanks for flagging this @jab1
Chris
Mouse25
Thank you so much for your help!
Mouse25
Will do! Thanks so much, Chris
Marsh
Fixes: 41
Hey @Mouse25,
I tried to call you today. However I failed to reach you I have updated the ticket on your account when your free please get back in touch with us below is a direct link to the question
https://www.plus.net/wizard/?p=view_question&id=251167254
Josh
Mouse25
Hello. Thank you. I have replied but can you please remove the public link to my question thread as it contains personal information. Thank you @Marsh
RobPN
Fixes: 13
@Mouse25
The link may be public but only you can see the information it leads to as you need to login to do so.
