Internet keeps disconnecting
prescottdevinne
My internet keeps disconnecting, and when it goes down, I get a message about "Can't connect to Broadband" which directs me to setup a username and password. But I already have, and it actually tells me that my username is [X]@plusdsl.net. I click on the link and the password hint is still working, and I type in my password and that works fine. Then, usually a few minutes later the internet is magically back up. This time however, the power light shows as blue but the internet is not working. After a few minutes like that, the power lights starts flashing orange. I have attempted to reset the router. Now the power light is blue again.
I've got a hub one, on regular internet with a double socket. I've had plusnet for months now and I've only had the issue in the last week.
8 REPLIES 8
LaurenB
Fixes: 131
Re: Internet keeps disconnecting
Hiya @prescottdevinne, I am really sorry for the issues that you are having with the service. I can certainly see there has been a high number of drops the last few days and I'm sorry for the disruption caused.
It looks like you have since raised a fault and an engineer been booked for you to get this sorted. Let us know how you get on!
 Lauren Barry
prescottdevinne
The internet just started doing the same thing again. It hadn't had an issue once since getting serviced, but it just went down before a big meeting at work. @LaurenB Would you be able to help?
Fixes: 1,663
Hi @prescottdevinne
I'm really sorry to see your broadband's started to drop again.
I can see the drop so I've tested your line, but the tests aren't showing the cause. I'd recommend keeping an eye on things, and let us know if you have further drops, as we may likely need to arrange another engineer to take a closer look.
I've attached below an updated graph of your connection. Smiley
Strat
Fixes: 565
Moderators Note
This topic has been moved from ADSL Broadband to Fibre Broadband.
prescottdevinne
Hello,
It just happened again. I'm being forced to switch to my phone's hotspot much more than I'm hoping. Could the issue be with the router, if it's not the line? I'm not stressing it out with a lot of connections or 4k video or anything. This is happening some of the time while a single device is searching google.
Thanks!
adam945
Fixes: 113
Thanks a lot for getting back to us @prescottdevinne and I'm sorry to hear that you're still experiencing issues with the service. I'll pop a visual radius and a GEA test below, the line isn't perfect (most lines aren't) but I'm not seeing anything to suggest that there's an underlying issue with the network. So I reckon you're right, and that there's an issue with the router.
I can see that you've already split the 2.4 and 5GHz SSID's, but I'll be more than happy to go into your router and run a Smart Wireless Scan. This automatically puts your router onto the best WIFI channels for your environment. This will drop the connection for a moment or two though, so I'll need the green light from yourself before I go ahead. Smiley
KBD
GEA Test Detail
Circuit ID NA Service ID
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 69.1 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Cross Talk Not Detected
Estimated Line Length In Metres 320.0
Upstream Rate Assessment Very Good
Downstream Rate Assessment Reasonable
Technology VDSL
Current 15Min Bin Retrains 0
Last 15Min Bin Retrains 0
DP Type External
Profile Name 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Retransmission High
Time Stamp 2022-01-19T23:15:00
Parameters MIN MAX AVG
Down Stream Line Rate 68.7 Mbps 72.2 Mbps 69.2 Mbps
Up Stream Line Rate 18.4 Mbps 19.9 Mbps 18.7 Mbps
Up Time 792.0 Sec 900.0 Sec 899.6 Sec
Retrains 0.0 3.0 0.0
Radius
 Adam
 Plusnet Help Team - Leeds
prescottdevinne
You've got the green light! Thanks for helping with this.
adam945
Fixes: 113
That's all been sorted for you. See how your connection gets on over the next few days and please let us know if you're still having any issues at all. Smiley
 Adam
