IP Profile reset request
BlackEagle
Requesting an IP profile reset
For the past 6+months th eline has been very unstable. Intially i was seeing speeds fo 65mb down and 18-19mb down It then dropped to 45mb down. now it keeps creeping down to 30mb then 8mb and was 5mb before i restarted the router whioch brought it back up to 8mb.
The line flucuates alot now mostlty at the speeds of 8/15/30mb. as you can can also see in the screenshot the upload speed which normally is uneffected has over halved in speed to 9mb.
Ping is very high at 30-47 too.
Was previosuly with BT on a stable 67mb down and 19 up. with a stable ping of around 8-15ms around the clock.
Another issue is if i were at full speed, and to download something over 9mb/s it would knock out my connection to the router for a few mins without fail every time
34 REPLIES 34
BlackEagle
Re: IP Profile reset request
After a second router reset and 30mins later after the Previous screenshot of the speed test
20mb down - 12mb up - 20ms ping
Fixes: 392
@BlackEagle That doesn't quite look to me to be a 'profile' problem - more like a network one to be honest. I suggest you follow my 'check' guide as below, excluding the BTW test which you have already completed.
 For Community members to be able to help, information from these two sites:-
BT Broadband(obscuring your phone number) and BTW Performance Tester - Please report the 'Additional Diagnostics', and sight of the Help Desk tab would be a start.
It may also be a good idea to report the results of a Quiet Line Test - dial 17070 option 2 from a (preferably corded) phone. After the confirmation of you phone number, there should be total silence apart from the regular 'Quiet Line Test' announcement. Any other noise - report a PHONE fault first.
BlackEagle
I do not hear any noise from the Quiet Line Test.
BTW performance tester in the screeenshot.
Fixes: 392
Thanks for that. No noise from the QLT is good.
Can you post your Help Desk from the router, please, and the WAN tab from the Event log? Picture below to help.
BlackEagle
Help Desk -> See Screenshot
WAN Log -> See below
Spoiler
Recorded events
Time and date Message
13:01:54, 06 Nov. ( 136.800000) WAN operating mode is VDSL
13:01:54, 06 Nov. ( 136.800000) Last WAN operating mode was VDSL
13:01:53, 06 Nov. ( 135.350000) PPP IPCP Receive Configuration ACK
13:01:53, 06 Nov. ( 135.350000) PPP IPCP Send Configuration Request
13:01:53, 06 Nov. ( 135.340000) PPP IPCP Receive Configuration NAK
13:01:53, 06 Nov. ( 135.340000) PPP IPCP Send Configuration ACK
13:01:53, 06 Nov. ( 135.330000) PPP IPCP Receive Configuration Request
13:01:53, 06 Nov. ( 135.320000) PPP IPCP Send Configuration Request
13:01:51, 06 Nov. ( 134.050000) PPPoE is up -​ Down Rate=72928Kbps, Up Rate=19999Kbps; SNR Margin Down=3.0dB, Up=6.1dB
13:01:51, 06 Nov. ( 134.040000) CHAP authentication successful
13:01:51, 06 Nov. ( 134.000000) CHAP Receive Challenge
13:01:51, 06 Nov. ( 134.000000) Starting CHAP authentication with peer
13:01:51, 06 Nov. ( 133.990000) PPP LCP Receive Configuration ACK
13:01:51, 06 Nov. ( 133.990000) PPP LCP Send Configuration Request
13:01:51, 06 Nov. ( 133.980000) PPP LCP Receive Configuration Reject
13:01:51, 06 Nov. ( 133.980000) PPP LCP Send Configuration ACK
13:01:51, 06 Nov. ( 133.980000) PPP LCP Receive Configuration Request
13:01:51, 06 Nov. ( 133.980000) PPP LCP Send Configuration Request
13:01:01, 06 Nov. ( 83.880000) PTM over DSL is up
13:00:13, 06 Nov. ( 35.370000) WAN Auto-​sensing running.
12:12:06, 06 Nov. ( 136.030000) WAN operating mode is VDSL
12:12:06, 06 Nov. ( 136.030000) Last WAN operating mode was VDSL
12:12:05, 06 Nov. ( 134.670000) PPP IPCP Receive Configuration ACK
12:12:05, 06 Nov. ( 134.660000) PPP IPCP Send Configuration Request
12:12:05, 06 Nov. ( 134.650000) PPP IPCP Receive Configuration NAK
12:12:05, 06 Nov. ( 134.650000) PPP IPCP Send Configuration ACK
12:12:05, 06 Nov. ( 134.650000) PPP IPCP Receive Configuration Request
12:12:05, 06 Nov. ( 134.630000) PPP IPCP Send Configuration Request
12:12:04, 06 Nov. ( 133.440000) PPPoE is up -​ Down Rate=73354Kbps, Up Rate=19999Kbps; SNR Margin Down=3.0dB, Up=6.1dB
12:12:04, 06 Nov. ( 133.420000) CHAP authentication successful
12:12:04, 06 Nov. ( 133.360000) CHAP Receive Challenge
12:12:04, 06 Nov. ( 133.360000) Starting CHAP authentication with peer
12:12:04, 06 Nov. ( 133.360000) PPP LCP Receive Configuration ACK
12:12:04, 06 Nov. ( 133.360000) PPP LCP Send Configuration Request
12:12:04, 06 Nov. ( 133.350000) PPP LCP Receive Configuration Reject
12:12:04, 06 Nov. ( 133.350000) PPP LCP Send Configuration ACK
12:12:04, 06 Nov. ( 133.350000) PPP LCP Receive Configuration Request
12:12:04, 06 Nov. ( 133.350000) PPP LCP Send Configuration Request
12:11:14, 06 Nov. ( 83.490000) PTM over DSL is up
12:10:25, 06 Nov. ( 34.910000) WAN Auto-​sensing running.
15:20:59, 21 Oct. ( 134.140000) WAN operating mode is VDSL
15:20:59, 21 Oct. ( 134.140000) Last WAN operating mode was VDSL
15:20:58, 21 Oct. ( 132.840000) PPP IPCP Receive Configuration ACK
15:20:58, 21 Oct. ( 132.830000) PPP IPCP Send Configuration Request
15:20:58, 21 Oct. ( 132.820000) PPP IPCP Receive Configuration NAK
15:20:58, 21 Oct. ( 132.820000) PPP IPCP Send Configuration ACK
15:20:58, 21 Oct. ( 132.810000) PPP IPCP Receive Configuration Request
15:20:58, 21 Oct. ( 132.800000) PPP IPCP Send Configuration Request
15:20:57, 21 Oct. ( 131.700000) PPPoE is up -​ Down Rate=73311Kbps, Up Rate=19999Kbps; SNR Margin Down=3.0dB, Up=6.0dB
15:20:57, 21 Oct. ( 131.680000) CHAP authentication successful
15:20:57, 21 Oct. ( 131.640000) CHAP Receive Challenge
15:20:57, 21 Oct. ( 131.640000) Starting CHAP authentication with peer
15:20:57, 21 Oct. ( 131.640000) PPP LCP Receive Configuration ACK
15:20:57, 21 Oct. ( 131.630000) PPP LCP Send Configuration Request
15:20:57, 21 Oct. ( 131.630000) PPP LCP Receive Configuration Reject
15:20:57, 21 Oct. ( 131.630000) PPP LCP Send Configuration ACK
15:20:57, 21 Oct. ( 131.620000) PPP LCP Receive Configuration Request
15:20:57, 21 Oct. ( 131.620000) PPP LCP Send Configuration Request
15:20:07, 21 Oct. ( 81.560000) PTM over DSL is up
15:19:20, 21 Oct. ( 35.310000) WAN Auto-​sensing running.
23:35:03, 27 Sep. (2008191.130000) WAN operating mode is VDSL
23:35:03, 27 Sep. (2008191.130000) Last WAN operating mode was VDSL
23:35:01, 27 Sep. (2008189.200000) PPP IPCP Receive Configuration ACK
23:35:01, 27 Sep. (2008189.190000) PPP IPCP Send Configuration Request
23:35:01, 27 Sep. (2008189.180000) PPP IPCP Receive Configuration NAK
23:35:01, 27 Sep. (2008189.180000) PPP IPCP Send Configuration ACK
23:35:01, 27 Sep. (2008189.170000) PPP IPCP Receive Configuration Request
23:35:01, 27 Sep. (2008189.090000) PPP IPCP Send Configuration Request
23:35:00, 27 Sep. (2008187.300000) PPPoE is up -​ Down Rate=73526Kbps, Up Rate=19999Kbps; SNR Margin Down=3.0dB, Up=6.1dB
23:34:59, 27 Sep. (2008187.290000) CHAP authentication successful
23:34:59, 27 Sep. (2008187.230000) CHAP Receive Challenge
23:34:59, 27 Sep. (2008187.230000) Starting CHAP authentication with peer
23:34:59, 27 Sep. (2008187.230000) PPP LCP Receive Configuration ACK
23:34:59, 27 Sep. (2008187.230000) PPP LCP Send Configuration Request
23:34:59, 27 Sep. (2008187.220000) PPP LCP Receive Configuration Reject
23:34:59, 27 Sep. (2008187.220000) PPP LCP Send Configuration ACK
23:34:59, 27 Sep. (2008187.220000) PPP LCP Receive Configuration Request
23:34:59, 27 Sep. (2008187.220000) PPP LCP Send Configuration Request
23:34:08, 27 Sep. (2008135.760000) PTM over DSL is up
23:33:31, 27 Sep. (2008099.240000) PTM over DSL is down after 20115 minutes uptime
23:33:31, 27 Sep. (2008099.240000) PPPoE is down after 20114 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 -​ Down)]
23:33:28, 27 Sep. (2008095.520000) PPP LCP Send Termination Request [User request]
00:19:06, 14 Sep. (801241.100000) WAN operating mode is VDSL
00:19:06, 14 Sep. (801241.100000) Last WAN operating mode was VDSL
00:19:04, 14 Sep. (801239.840000) PPP IPCP Receive Configuration ACK
00:19:04, 14 Sep. (801239.840000) PPP IPCP Send Configuration Request
00:19:04, 14 Sep. (801239.820000) PPP IPCP Receive Configuration NAK
00:19:04, 14 Sep. (801239.820000) PPP IPCP Send Configuration ACK
00:19:04, 14 Sep. (801239.820000) PPP IPCP Receive Configuration Request
00:19:04, 14 Sep. (801239.810000) PPP IPCP Send Configuration Request
00:19:03, 14 Sep. (801238.730000) PPPoE is up -​ Down Rate=70483Kbps, Up Rate=19999Kbps; SNR Margin Down=3.0dB, Up=6.1dB
00:19:03, 14 Sep. (801238.710000) CHAP authentication successful
00:19:03, 14 Sep. (801238.680000) CHAP Receive Challenge
00:19:03, 14 Sep. (801238.670000) Starting CHAP authentication with peer
00:19:03, 14 Sep. (801238.670000) PPP LCP Receive Configuration ACK
00:19:03, 14 Sep. (801238.670000) PPP LCP Send Configuration Request
00:19:03, 14 Sep. (801238.660000) PPP LCP Receive Configuration Reject
00:19:03, 14 Sep. (801238.660000) PPP LCP Send Configuration ACK
00:19:03, 14 Sep. (801238.660000) PPP LCP Receive Configuration Request
00:19:03, 14 Sep. (801238.660000) PPP LCP Send Configuration Request
Fixes: 392
Your WAN log is showing a number of disconnections from the network - which isn't a good sign. Can't see the Help Desk screenshot.
BlackEagle
Correct, i have to frequently restart the router in an attempt to sometimes "fix" the slow connection
My appologies i didnt upload it
Fixes: 392
Thanks for that. From the Help Desk picture, the only thing that stands out is the 3dB U/S noise margin, although that could be a red-herring, given your line and signal attenuation figures - you must be sat almost on top of your local cab.
To be honest, I can't see anything in the detail you have provided to give rise to your connection problems, but a profile problem it certainly isn't.
Hopefully, one of the Help Team will pick this up and carry out tests which may give us a better clue as to the problem, but please be aware it is the weekend and they are a little thin on the ground.
I would avoid rebooting the hub too often - eventually DLM will assume you have a problem and intervene.
Fixes: 480
@jab1
Sorry to but in but I can only see one disconnection, this was after being up for 14 days, the rest are CHAP requests.
The line connection is good.
I suspect that this is a wireless issue.
@BlackEagle are you testing over a wireless link? If so see what it's doing over an Ethernet connection.
Fixes: 392
No problem, @Baldrick1 - I admit to misreading that log.  I also suspect a wireless issue, having been thinking about it.
BlackEagle
This is over Wireless, Ethernet is not currently possible unless i were to get 40m ethernet cable. Like i say before i used to sit at 60mb up and 18 down over wireless (using Asus pc-88 wireless card + external antena's). recently its been capping out at 40-45mb and often sitting at 30/15/8mb til a restart the router with 50/50 success chance of it going back up to 45mb.
EDIT: I also own a cheap £5 2.4ghz wireless usb and it is also giving the same results.
Fixes: 392
It is possible in that case it could be the hub - did you use another one when getting the higher speeds?
BlackEagle
Nothing has changed in the past two years. locations, hub, pc/wireless adapter.
Fixes: 480
@BlackEagle
It’s not expensive if you are desperate https://www.amazon.co.uk/World-Data-BLACK-Premium-Network/dp/B00O91S44K/ref=sr_1_5?adgrpid=568172035...
If you log in to the hub you can see the firmware version. If it ends 263 or earlier then there’s a firmware update that might help, add a message to this thread. https://community.plus.net/t5/My-Router/Hub-One-5GHz-WiFi-issue/m-p/1696363#M15510
