Hub2 router
dartilov
Hub2 router
Had full fibre installed a few weeks ago.  Can I dispose of the old Hub1 router or will Plusnet need/want it back?
1 REPLY 1
Fixes: 480
Re: Hub2 router
@dartilov
You can post it back or even ask the Post Office to collect it for free, see  https://www.plus.net/help/broadband/returns/
Alternatively, it will work on your Full Fibre service if you connect via the red WAN socket, so you can keep it as a spare. The only downside is that the upload speed is limited to 30Mbps.
