Hub2 router
- Full Fibre
- Re: Hub2 router
Hub2 router
12-11-2022 1:17 PM
Had full fibre installed a few weeks ago. Can I dispose of the old Hub1 router or will Plusnet need/want it back?
Message 1 of 2
(834 Views)
1 REPLY 1
Re: Hub2 router
12-11-2022 1:34 PM
You can post it back or even ask the Post Office to collect it for free, see https://www.plus.net/help/broadband/returns/
Alternatively, it will work on your Full Fibre service if you connect via the red WAN socket, so you can keep it as a spare. The only downside is that the upload speed is limited to 30Mbps.
