How to set up Hub Two for full fibre
FIXED- Subscribe to RSS Feed
- Full Fibre
- Re: How to set up Hub Two for full fibre
09-08-2022 10:47 AM
Hi, I'm moving to a house that doesn't have a telephone line, and we'll be using Full Fibre. The router Plusnet sent is a Hub Two but the instructions are about how to plug it into the telephone line. This must be a mistake, can anyone help me work out whether we can use this router but just need to set it up differently, or whether we need a different router altogether? Thanks.
Fixed! Go to the fix.
09-08-2022 11:34 AM
Does it have a Red WAN port (+three Yellow Lan ports).
If it does you plug an ethernet cable into the Wan port.
09-08-2022 11:36 AM
Thank you - yes, it does have those ports. And what do I do with the other end of the ethernet cable?
09-08-2022 11:36 AM
For more details check here
https://www.plus.net/help/broadband/router-setup-guides/hub-two-full-fibre/
HTH
- Full Fibre
