Full fiber router
Clitherow
Full fiber router
I have received my new router today my service goes live on Tuesday but they sent the adsl one with the micro filter cable , do I just have to find a network cable to go into the wan port or is the internal config different
5 REPLIES 5
Fixes: 357
Re: Full fiber router
@Clitherow Which router is it? A Hub2 presumably, and it should have  an ethernet cable with it.
Clitherow
Yes router 2 but no red cable as in the install video but an rj45 to fj11 and a micro filter and a network cable cat5
Fixes: 357
The cat5e cable is the 'red-ended' one - it appears that they have run out of the coloured ones. The red ends were/are merely to make it more obvios which you inserted into the WAN port.
Fixes: 466
@Clitherow   Welcome to the Plusnet Community Fora.
Unfortunately, it looks like you have been sent the wrong packaged version of the Hub. The FTTC versions are shipped with a DSL cable plus a yellow ended Ethernet cable, The FTTP versions come with no DSL cable but two Ethernet cables, one yellow ended, the other red. As @jab1 states, the cables are identical apart from the colour of the plugs.
Any CAT 5e or better Ethernet cable can be used.
Fixes: 558
either that or @Clitherow s order is for Fibre and not Full Fibre ?
