Full Fibre physical installation.
Fixes: 117
Re: Full Fibre physical installation.
@jab1
My grey matter has caught up. I only get Full Fibre offered as I was on ADSL before with no FTTC available for technical reasons. Despite living in a reasonable sized community.
This was why when OR ramped up the Full Fibre deployment in late 2017 we were one of the first to benefit. We'd been complaining loudly.
UPRN gave my old Exchange, Address version gives the current main Exchange.
JayEeeCee
Yes, I did note down the info in the drop-down pertaining to my address. I recognised the second number because of the first 2 letters and what they meant.
I just wasn't sure what the first number was but now I know it's the UPRN, I could check the same look up from your previous link but still shows the same details as before.
I can try it again in a few days to see if it changes.
The install is in the cupboard under the stairs not far from the back of the cupboard so I'm perfectly happy with it.
If the install was done on an exposed wall in our hallway etc., it would be a different story!
There is now storage shelving next to it (which is why the picture looks a bit dark!) so it won't ever get disturbed unless I go in there.
Similarly, the copper line which you can still see, also never got disturbed except when my spark fitted the trunking.
Thanks again for all the help. At least my knowledge has caught up again!
