Full Fibre 900 Wi-Fi issue.
OldGeorge70
Hi Folks,
I've upgraded from FF 140 to FF 900 today, over Wi-Fi I was getting the full 140 Mbps under my old plan, today I'm maxing out at around 250 Mbps. When I connected a ethernet cable from the bedroom my Plusnet router is in, to my desktop PC across the landing I get the full 900+ Mbps.
It isn't practical for me to have a long length of cable between two bedrooms, and my PC's Wi-Fi card is capable of handling the speed, so what is the potential problem?
My Wi-Fi card is a 9 month old Cudy WE3000 AX3000 Wireless WiFi 6 PCIe Card - Speeds: Up to 2402 Mbps on 5GHz and 574 Mbps on 2.4GHz.
This lack of speed has me puzzled, I've move the antennas on the Wi-Fi card in different direction but this hardly makes a difference, and I've upgraded the cards drivers but this has not improved performance.
11 REPLIES 11
Re: Full Fibre 900 Wi-Fi issue.
If you have a Hub Two it is only WiFi 5.
You need a WiFi 6 or better router to achieve faster WiFi speeds.
You will need to buy a third party router.
Terranova667
Fixes: 8
I'm on full fibre 900 and with the Hub Two using a Wi-Fi 6 certified laptop I can get just over 500mb but I have to be practically sitting on the router in the hallway to get it, if I go to the kitchen or the livingroom which is only a few feet away I get around 250-350 depending on interference etc, Via Ethernet which my main PC uses i get the full 900+
So the Hub two is capable of 500mb just that it's range is not very good, so I would recommend getting a third party Wi-Fi 6 router that has better range if going via Ethernet is not an option.
Fixes: 579
@OldGeorge70 Just confirming what others have said...
I have a Wifi 6 capable laptop, when using a Wifi 5 router (not a Hub 2 btw) it would max out at around 400Mb. Using a Wifi 6 capable router gives around 750Mb.
OldGeorge70
Hi Guys,
Thank you for your replies, could you suggest Wi-Fi 6 routers that are reasonably priced and suitable for working with Plusnet?
Thanks in advance.
Fixes: 117
@OldGeorge70
I believe the FritzBox 7530AX meets your needs. A well regarded router though you'd need to look online for the full specs. I use the non WiFi6 version on my PN account. Second hand from £52
https://uk.webuy.com/search/?stext=fritzbox+routers
mystreet1
Seasoned Pro
Fixes: 7
Good secondhand one, AVM Fritz! Box 7530AX.
One currently on CEX for £52.
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
mystreet1
Seasoned Pro
Fixes: 7
@bmc beat me to the Fritzbox
Or
Cudy ax3000
https://amzn.eu/d/084MLlLT
OldGeorge70
Hi Guys,
Apologies for the late reply.
Thank you all very much for your kind help, I've just ordered the Fritz! box from CEX, looking forward to it's arrival.
I will be back to update you on the results of adding the Fritz box to my FF 900 connection in due course.
Many thanks again!
Fixes: 117
@OldGeorge70
When I bought my 7530 from CEX it was the router of choice for Zen Internet and they had a good help page for settings required for Full Fibre. I also found the users manual on the FritzBox site and down loaded that.
What you need to do first is a factory reset in case the router is an ex Zen unit. The reset is software controlled - there is no button to press.
OldGeorge70
Hi Brian,
Thanks for the reset tip, I've already downloaded the manual in anticipation.
mystreet1
Seasoned Pro
Fixes: 7
If you want to remove the Zen software, have a look at this
https://www.geekzone.co.nz/forums.asp?forumid=85&topicid=148507
It worked for my 7530, don't know about the 7530ax.
