Frequent Disconnects
blandifer
Re: Frequent Disconnects
Hi - many thanks for all your comments. I'm afraid I can't respond to the technical stuff (far too complicated for me) but I welcome your comments and I look forward to Plusnet responding!
SammyM
Fixes: 101
Hiya @blandifer,
I am really sorry to hear the issue is still ongoing and for the inconvenience this is causing.
I have run tests on your line and it is not showing any cause for the drops and looks spot on.
I have arranged for a new router to be delivered which will be with you in the next 3 to 5 working days.
Please can you try the new router and get back to me with how the connection performs?
 Sammy M - Sheffield Team
blandifer
Many thanks - will try new router and let you know what happens
blandifer
New router connected Tuesday evening and internet has not gone down since.
I will keep an eye on things for a few more days but it looks like replacement router has sorted it!
Fixes: 245
Can you please post the router line stats. The router might not have fixed the issue so much as it is simply better at hanging onto a marginal line.
blandifer
Find attached the event log (WAN tab) from the new router since it was switched on on Tuesday - it only runs for about 5 minutes then stops.
I have not noticed any internet disconnects since the new router was installed on Tuesday.
Fixes: 245
That’s not what I was asking for … but it nonetheless is helpful.
You appear to be on basic fibre 40/10 not extra - is that correct?
Also though in that short log snap shot there are two xDSL disconnects albeit so swift you might not have noticed them.
@Gandalf what does the radius plot look like please?
Fixes: 1,662
Hi @blandifer
I'm glad to see your new router's working well.
I've just checked your connection (attached a graph below) and things do indeed to be stable now.
If you have any further issues, feel free to get back to us. Smiley
blandifer
Thanks to all those who responded - things do seem stable now so I will close this topic
Fixes: 245
Odd behaviour - sought to report to mods but it ended up as a post!
