Broadband speed slower then expected
Frenchy80
I joined Monday and i know it takes around 10 days for speeds to settle
When i joined my speeds were guaranteed to be around Estimated download speed 71-72mbps
In the router it's got
Downstream:
79.987Mbps
Upstream:
20Mbps
However since Monday i've barely near 70Mbps with probably 5.0Mbps the closest i've got
15 REPLIES 15
Fixes: 357
Re: Broadband speed slower then expected
@Frenchy80 What username is showing in the Hubs (which one?) user interface?
Welcome to the forums, btw.
Frenchy80
Showing my username i signed up with @plusdsl.net
Fixes: 357
OK, so that is one idea out of the window - a pity, as it is the easiest fix. Can you follow the below, please,  and I'll see if I can spot anything?
For Community members to be able to help, information from these two sites, as screenshots:-
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the HELP DESK tab from your Hub would be a start.
I may not get back to you tonight, but I'm around fairly early in the morning, so I'll check then.
Frenchy80
I have Text Plusnet today and seems i got a fault on the line
Fixes: 357
OK - would have been nice to have seen a reply last night, though.
adamwalker
Fixes: 223
Hi @Frenchy80
I'm really sorry about the problem with connection speeds you've been having, thanks for reporting a fault with us, that's been raised to Openreach so please bear with us and we should have an update for you within the next 72 hours.
 Adam Walker
Frenchy80
Went in to the router today and noticed that if i'm on 2.4ghz my speeds are lower then 5ghz setting which are full on
Only trouble is Sky Q box does not take the 5ghz
Anyway i can change things around so that i can put certain ones on 2.4ghz and others on 5.0
Fixes: 1,491
Not if you have a Hub 2, sadly.
SammyM
Fixes: 101
Hiya @Frenchy80,
As dvorak has said you are unable to split the bands on the Hub Two, but you can turn off the bands.
 Sammy M - Sheffield Team
Frenchy80
Thanks for the replies
I've noticed my speeds have some what improved on the 2.4 from 1.5mbps to 4mbps which i can live with however if i move to 5ghz i can get full speeds but with a twist i can't connect to Sky main box and few others apps Sad
SammyM
Fixes: 101
I can see that we had a fault raised for you @Frenchy80 and our suppliers have rectified an external fault.
Is there anyway you can check the speed an a wired connection to ensure it is solely a wireless connection.
Frenchy80
I have finally solved the issue
I've gone in to my computer and changed the Wifi band to 5GHZ and got full speeds going
Kept the Router both at 2.4 and 5ghz and everything seems to have been solved
Fixes: 1,652
Excellent! Cheers for posting back, I'm glad you've got full speed now.
Let us know if there's ever anything else you'd need help with and we'll be happy to help. Smiley
Frenchy80
Could staff please check my account and see if the request of cancellation on the 30th has been stopped as now i'm getting max speeds i want to stay on Plusnet
I did msg on Twitter earlier today but as of yet had no reply
Cheers
