Fibre upgrade
esther1980
Fibre upgrade
I upgraded to fibre and got confirmation it would apply from 07/01/22 and got the new hub 2 plugged in and working etc.
The first few days the speed seemed mega fast compared to what i was used to, then a week later im back to the cruddy 2-3mbps !
on my account everything says its set up and ok etc.
Did all the checks and still a totally naff speed and the text bot help says no issues with the line.
So how does the speed start ok then just drop and stay low?
different speed tests show different speeds but mainly slow and low
8 REPLIES 8
Fixes: 379
Re: Fibre upgrade
@esther1980 This sounds like you are still in 'set-up' mode on the Hub. What is the 'Username' on the Helpdesk page of your Hub - '[email protected]' or '[email protected]'?
esther1980
Re: Fibre upgrade
Hi
Its the first one with plusdsl.net
Fixes: 379
Re: Fibre upgrade
OK. In that case, we need a bit more information.
For Community members to be able to help, information from these two sites:-
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection please report the 'Additional Diagnostics', and sight of the Help Desk tab from your Hub would be a start.
It may also be a good idea to report the results of a Quiet Line Test - dial 17070 option 2 from a (preferably corded) phone. After the confirmation of you phone number, there should be total silence apart from the regular 'Quiet Line Test' announcement. Any other noise - report a PHONE fault first.
If phone test is OK then take the front off your telephone master socket, you may need to remove two screws. In behind you will find the test socket. Plug a filter in here and connect that to your hub. If it’s still dropping out then report a fault at https://faults.plus.net.
Fixes: 1,662
Re: Fibre upgrade
Thanks for your post @esther1980
I'm really sorry for the delay with your fibre order.
From what I can see it was delayed to the 8th February due to engineer availability in your area.
Let us know how it goes.
Fixes: 379
Re: Fibre upgrade
So the OP is still on ADSL? Didn't read that way (to me) from the initial post. 😕
esther1980
Re: Fibre upgrade
8th feb !
Thanks for letting me know as I haven’t had any communication to say there was any change or issue, last email said 7/1/22 and when i logged in it appears to all be sorted, and from what i have read i didn’t need to do anything and it would all just change automatically.
Odd that i got some fast speeds with the new router initially.
Fixes: 1,662
Re: Fibre upgrade
No problem, I can't explain that either, but you're definitely still on standard broadband.
Things will change over automatically so you don't need to do anything, but it'd need an engineer to go to the cabinet (the green box in the road) to carry out the work and based on the delay, it looks like they're very busy. Sad
Strat
Fixes: 565
Re: Fibre upgrade
Moderators Note
This topic has been moved from ADSL Broadband to Fibre Broadband.
