Fibre externally cabled
Patriotk11
Firstly, open reach have arrived over an hour late.
No messages or contact as plusnets email said I'd get.
No discussion about where I want the cable. It's either in to my hall way where I have no power. Or a black ugly cable running around the outside of my house to where my current point is. I asked could it not be fed in like the current cable. Apparently not as that'd be difficult so it's either the external cable or nothing.
Absolutely raging. Not a good start at all!
3 REPLIES 3
bgiles
Re: Fibre externally cabled
@Patriotk11
Sorry to hear about your disappointment.
Unfortunately fibre-optic cables cables have a minimum bend radius of about 20mm, so much greater than copper twisted pair used for ADSL/FTTC. This makes the routing far more restrictive, and often the most challenging aspect of the installation.
Plusnet SoGEA
DrayTek Vigor2762 VoIP Router
Patriotk11
Now damaged my brick work.... What the actual... He didn't even say anything.
How do I upload a pic?
Fixes: 383
@Patriotk11 Providing you are using a desktop/laptop, save the picture to your machine, then open a reply window and click the 'mountain ' icon to the right of the smiley one, and follow instructions.
