FTTP upgrade - can I use eero?
woodsy2
Hi
I am considering going with Plusnet FTTP (it is available). It comes with a Plusnet Hub2? I currently have an Eero mesh (3 Eeros)to get good Wifi throughout the house. Before I sign up I could do with some info please folks
Questions
  • can I replace the Plusnet Hub2 and connect one Eero direct to the ONT?
  • Or can I connect an Eero to the Hub2 to use the mesh
(The eero site isn't really very helpful about this as I don't think they have clocked Plusnet offering FTTP yet)
Any advice most welcome here. (I doubt I can be alone with this question?) Thanks
3 REPLIES 3
Fixes: 558
Re: FTTP upgrade - can I use eero?
According to this https://support.eero.com/hc/en-us/articles/5382599417371-PPPoE-Setup-Instructions the Eero supports PPPoE . You should be able to connect directly to the ONT and configure the EEro for PPPoE with your Plusnet username & password
woodsy2
Thanks Mr W. So in that eero article it says the ppoe login is not various things, but for plusnet it is the normal login I use now?
Thanks again
Fixes: 558
Yes , it's <accountname>@plusdsl.net & the password you use to login to the member centre
