FTTP coming to my area
- Full Fibre
- FTTP coming to my area
Re: FTTP coming to my area
07-02-2018 9:25 PM
@strongylad28 does this make any sense if you walk the street? Are the houses set out in clumps or is it just one long street?
09-02-2018 11:53 AM
Its basically a long cul-de-sac that has a 90 degree bend in it. The houses are really only even numbers until you get to the end of the cul-de-sac and then theres the occasional odd number. The odds on the checker show as not available, but the evens are.
10-02-2018 12:57 PM
Here's the link: https://www.formwize.com/run/survey3.cfm?idx=505d040e0b080d
Sorry if I'm repeating advice previously given.
Rob
12-02-2018 3:17 PM
Hi Rob
This sounds somewhat similar to my situation (see my earlier post on this forum).
The OR line checker page shows "In Scope" for my phone number, but shows "Ultrafast accepting orders" for my postcode. Our postcodes were changed some years back by Royal Mail, and upon contacting OR by the online form you describe, they admitted that they were still using our old contact details!
Work here seems to have finished on the poles and exchange prior to January, probably in the last big push. I've been exchanging emails with a member of the OR customer facing team, but where they started out responding personally, the most recent response was with a template email
Is there any pressure PlusNet can add to reviewing the availability? If you request FTTP setup using my postcode only it might work, if you try with my phone number it will probably be declined!
12-02-2018 3:19 PM
I have, unfortunately I just get a generic "you cant have fibre" email.
I am speaking to them on twitter however so might be able to sort something there.
12-02-2018 5:42 PM
Rob
12-02-2018 11:20 PM
Thanks Rob. Ticket raised is #168271771. Full details of my address/line number enclosed!
13-02-2018 8:20 AM
@Anonymous is it worth me opening a ticket? Historically I was always told that nothing could be done until the OR checker said yes, but based on your last reply it looks like you may be able to sort something on your end?
13-02-2018 9:40 AM
Today is a momentous day!
A couple of OR engineers knocked on my door this morning and said they have had word from their bosses, bosses boss that they needed to sort this as a matter of urgency. They have ran and coiled up the fibre to my front door now! Next stage is to get the checker sorted and the engineer install should be a piece of cake.
I got both their names, and pictures of the van reg to use if I need to haha.
13-02-2018 9:46 AM
@strongylad28 great news Make sure you link to this forum thread when you raise your ticket. Bear in mind it may take some time for the systems to update so we can place an order.
13-02-2018 9:49 AM
I most certainly will do. I will keep on the checker to get an order placed ASAP!
13-02-2018 9:53 AM
13-02-2018 6:19 PM
13-02-2018 6:52 PM
13-02-2018 7:21 PM - edited 13-02-2018 7:22 PM
There's a new style of install which requires only one visit. The Distribution Point has "ports" where pre-connected cable is plugged into. The cable is then run to the premises, brought indoors and then connected to the ONT. Only one fibre optic "join" is required.
The DSL Checker will return a result which states "1 stage" or "2 stage" which tells you whether it's a old or new style install.
The following link has more detail
http://blog.thinkbroadband.com/2016/06/a-peek-at-the-future-world-of-openreach-fttp/
