FTTP coming to my area
- Full Fibre
- FTTP coming to my area
Re: FTTP coming to my area
08-04-2018 9:25 AM
19-04-2018 5:24 PM
19-04-2018 5:31 PM
20-04-2018 3:44 PM
I have been waiting for this day for so long! I finally have FTTP!!!!
72mb down and 21mb up!!!!!!
20-04-2018 4:04 PM
20-04-2018 4:12 PM
We did, and thank you very much for all of your help @Gandalf, I really appreciate it!
20-04-2018 4:18 PM
20-04-2018 4:23 PM
It certainly is! I have only used it for a short period of time as I am away this weekend (typical!) but it downloaded an app that would normally take 5 mins, in seconds!!!
Yep I wasn't going to let this get the better of me. The next job is to work out how I can get my neighbours to have it! They are on the same DP but cannot order. The engineer even said to me that he checked the node and i am in port 1, and only port 1 is in use. Fingers crossed I can help them out too!
20-04-2018 6:33 PM
My fiancé tells me the broadband is down despite it working when I left. And I cannot connect to my cctv remotely, again I could do this earlier.
@Gandalf do you know why this would have been working earlier but now it has gone down?
20-04-2018 7:37 PM
Looks like this was short-lived.
Your FTTP order completed on the supplier systems at about 5pm, so I've now changed your account type accordingly over to your fibre package, though this wouldn't affect your connection.
Our tests are basically just showing this:
Test Outcome | Fail |
Test Outcome Code | GTC_FTTP_SERVICE_1005 |
Description | ONT is down, Check that ONT is plugged in and switched on. Continue submitting trouble report |
Main Fault Location | CA |
Sync Status | Down |
Appointment Required | Y |
Fault Report Advised | Y |
Assuming the ONT is powered on still, we'll need to raise a fault with our suppliers and arrange an engineer visit to further investigate. If you can reply to your ticket and/or text I've sent just now, we'll book it in for you.
21-04-2018 12:24 AM
I'm not home so I can't check the connections but on Monday evening I'll make sure everything is plugged in correctly
22-04-2018 7:04 PM
Well done guys, I hope the girlfriend didn't turn the new white box off! But if all goes well Champagne and ticker tape all round.
And now to get the neighbors sorted!
23-04-2018 10:36 AM
@Gandalf are you able to have a check of the connection since it went down, and see if there have been any other drops?
It seems to be working now but I don't know if the fault is intermittent or it was just a one off
24-04-2018 10:43 AM
24-04-2018 11:25 AM
How would I go about ceasing my old service and PSTN? I know there is an early cancellation fee, could you calculate that for me please?
