FTTP and IPv6
henryfairpo
FTTP and IPv6
Hi
About to move from FTTC to FTTP as it is now installed here.
I believe that BT Openreach automatically enables IPv6 so is this now available on Plusne through the equipment provided?
7 REPLIES 7
Fixes: 383
Re: FTTP and IPv6
Plusnet do not currently offer IPV6.
henryfairpo
Re: FTTP and IPv6
Thanks @jab1
Very strange as it is automatically enabled by their own parent company!
Fixes: 383
Re: FTTP and IPv6
The Plusnet system is totally different to that of BT Broadband, and IPV6 is enabled at server level.
Fixes: 117
Re: FTTP and IPv6
@henryfairpo
IPv6 costs money. Separate servers from IPv4 and the need to run software to manage the connections between each.
PlusNet is the budget brand of the BT Group so doesn't spend money where it's not needed. The loss of business from those who need IPv6 is presumably less than the cost of implementing it.
henryfairpo
Re: FTTP and IPv6
Hi Brian
Amusingly BT don't understand why Plusnet don't have it.
I'm going elsewhere as a result.
Fixes: 383
Re: FTTP and IPv6
BT Broadband and PN are run as two separate concerns, so BT CS wouldn't know anyway.
steveedz
Re: FTTP and IPv6
Thanks saved me from asking the same question
