FTTP Static IP
henrymaidment
FTTP Static IP
Hello!
I've just had my FTTP 550:75 go live, but when I try to 'activate my static ip' the page refreshes and nothing happens.
Thanks,
Tags (1)
10 REPLIES 10
Fixes: 387
Re: FTTP Static IP
Have you asked and paid for a static? You have to do this either by calling up, or better still requesting it through the forum - post a request on the 'Everything Else' board.
Tags (1)
henrymaidment
Re: FTTP Static IP
Yeah I’ve paid for the static IP option, it’s when you’re on the page to activate it after paying. You click ‘activate’ the page refreshes, and nothing happens. I’ve tried activating it then rebooting my router in order to redial but it still says ‘you are currently using a dynamic ip’
Tags (1)
Fixes: 387
Re: FTTP Static IP
Rebooting the Hub should automatically activate the static IP, although I have heard of your comment previously. As static IP's are allocated from a different 'pool' to dynamic, can you post the first three octets of your current external one, please - I may b able to tell you whether you have a static from that, otherwise I can ask elsewhere.
FYI - the 'activate your static IP' page doesn't work, a bit like the automatic ordering of one doesn't.
Tags (1)
henrymaidment
Re: FTTP Static IP
Cheers for the info! first three groups:
195.213.230
Thanks,
H
Tags (1)
Fixes: 387
Re: FTTP Static IP
I'm not 100% sure, but this could be a static. When I see one of the 'experts' on here, I'll ask them to check for you.
Tags (1)
Fixes: 585
Re: FTTP Static IP
The definitve test is to check the rDNS. A dynamic IP will return something like <ip address-dyn>.plus.net  whereas a static IP will return (by default) <accountname>.plus.com
Tags (1)
Fixes: 387
Re: FTTP Static IP
Cheers, @MisterW - forgot that, still need my second coffee of the morning. 😉
Tags (1)
henrymaidment
Re: FTTP Static IP
thanks all! I've checked but it is saying dyn so it is still dynamic unfortunately
Tags (1)
Fixes: 585
Re: FTTP Static IP
I'm sure one of the Plusnet staff will be along shortly to sort it....
Tags (1)
MatthewWheeler
Fixes: 503
Re: FTTP Static IP
Hi @henrymaidment
That should be sorted for you now
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
Tags (1)
