FTTP Download Speed 2 Mbps
cornwallsurfer
Can somebody please look at this. I reported this problem on 01/11/14 and nothing has been done to investigate this yet. The FTTP is unusable. Be better off with ADSL.
13 REPLIES 13
AndyH
Re: FTTP Download Speed 2 Mbps
What's your Current Line Speed here https://portal.plus.net/my.html?action=data_transfer_speed ?
cornwallsurfer
Current line speed is showing as 2Mb! It should be 76Mb
AndyH
Hopefully MattyC will pick this up as it's a PN profile issue.
Oldjim
Fixes: 63
I have moved this thread and some of your earlier ones to this board as it is the FTTP Trial you are discussing
cornwallsurfer
Thanks AndyH.
MatthewWheeler
Fixes: 437
Hi there
I've tried to find your account but your community username is linked to a destroyed account  Undecided
Can you PM me your username and I'll get the ptofile changed for you
 Matthew Wheeler
SpendLessTime
Fixes: 86
Matthew
For future reference purposes could you possibly list the correct Plusnet line speeds for all the various FTTP offerings e.g. 80/20, 100/30 etc.
Thank you.
AndyH
I think they have one profile for all on FTTP now (300Mbps).
MattyC
Fixes: 46
Quote from: AndyH
That'll be me then! With regards to the speeds; it's actually dependent on when in the trial they were provisioned. Some will be on 330/30, and other more recent provides will be on 80/20 (or 40/10 if requested). I'm not sure that I'd be able to give you all a specific date on when we made the change.
@cornwallsurfer - Feel free to pop myself or Mr Wheeler a PM regarding this one if it's not sorted yet. I'm pretty sure it's a simple issue.
SpendLessTime
Fixes: 86
The reason I asked was that mine has been put down to
"Current line speed:
77.4 Mb"
from the 300Mb.
So really wondering if that is correct?
dave
It should be show one of the following depending the speed of the FTTP service:
40/10 - 38Mbps
80/20 - 77.4Mbps
100Mbps or 330Mbps - 300Mbps
The 100Mbps product was withdrawn by Openreach earlier in the year but there's still a few people on it.
Dave Tomlinson
Plusnet Technology
f513toy
I am experiencing sloooow speeds also and also have to disconnect the openreach box pretty much two/three days a week sometimes to get things going again - was particularly bad over the weekend. Please can someone check - is it the openreach box (I was one of the first on the trial so maybe it needs upgrading) or the line?
Yes, I am also curious about what is happening regarding the 100Mbps speeds now that is withdrawn - will I / have I been moved up or down and when will I know / get asked?
40/10 - 38Mbps
80/20 - 77.4Mbps
dave
The plan was to contact those people on 100Mbps about switching to a different speed, most likely 80/20, however we've been able to keep everyone on 100Mbps so we've decided to leave everyone as is. If Openreach want us to move people then we'll contact you to let you know but last I heard they didn't have any problems leaving the few that were left as is.
I've run a line test but it's not shown any problems, but if it is the Openreach box it may not show up in the test, especially if it isn't happening at the point I ran the test. What happens when it gets slow? Is it gradual or a sudden change? Can it happen at any time? When you disconnect/reconnect the Openreach box do you switch the power off and does it go back to normal as soon as it comes back on or does it take time?
Dave Tomlinson
Plusnet Technology
