Engineer did arrive (better late than never!)..
- Full Fibre
- Profile still stuck.
Re: Engineer did arrive (better late than never!)..
09-05-2011 8:14 PM
I'll be asking our installer for all the numbers tomorrow... better start writing the questions down, so I don't forget
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
09-05-2011 8:17 PM
I'd estimate 36 d, 8 u though speed tester gives me 33/8
I have seen higher than 33 however so not sure about that. 36 could have been pre-training.
10-05-2011 12:46 PM
10-05-2011 12:49 PM
Re: Profile still stuck.
10-05-2011 1:22 PM
I'll go look at your profile now.
10-05-2011 1:24 PM
Please don't scatter gun the forums as it makes it difficult for the Digital Care Team to keep up
10-05-2011 2:49 PM
Noticed it's now been updated - thanks. Will check out my new speeds after work. Engineer got 40 so fingers crossed for 37 after training.
10-05-2011 3:37 PM
11-05-2011 4:33 PM
31 is good buy hoping for as much as possible
11-05-2011 4:49 PM
The estimates do seem to be quite cautious.
11-05-2011 5:06 PM
The cabinet is 500m by either possible route to the house.
13-05-2011 3:27 AM
13-05-2011 7:07 AM
PN Have hinted they will consider (sorry, can't get any less committal) offering 10Mbit uploads in the future. (Yep, hint, consider, future.... don't hold your breath!).
16-05-2011 12:36 PM
Quote from: WWWombat BT's checker estimates gives 30.1/6.2, Plusnet estimates 30.
I'm estimated 30 by BT and plusnet, my box is over the road!!!!!!
Must be about 30m in cabling, pretty sure I should be getting more than you.
16-05-2011 4:11 PM
We aren't on the closest cabinet - but that was installed after the house was built, so is kinda obvious. There is also a cabinet directly inline between us and the exchange, which would make the total line length shorter (but our house-cabinet length would be longer); we're not on that either. The cabinet we *are* on means that the full line takes a large extra loop on the way back to the exchange.
Yet knowing when our estate was built, and the order it was done in, you can tell where the BT wiring goes out to the cabinet. The distance is then obvious, and very much matches the BT prediction.
What does BT's DSL checker tell you? http://www.dslchecker.bt.com/adsl/adslchecker.welcome
