Download speed dropped by ~20Mbps
longedge
Fixes: 4
Until last Monday I was getting around 44Mbps / 8Mbps. I'm now getting around 22Mbps / 7Mbps. I also seem to have acquired a fixed IP as I can't make it change despite having disconnected completely and also re-started my session numerous times.
I notice that I'm not the only one experiencing a large drop in speed. Is there a general problem?
My current router stats-
18 REPLIES 18
Mustrum
Fixes: 81
Re: Download speed dropped by ~20Mbps
Your router stats show you are getting 48Mbps.
You noticing that other people having problems is not surprising given that's what most come on here for - unless they are your neighbours it's unlikely there is a connection.
longedge
Fixes: 4
Yes, I'm synced at what is my normal rate in fact everything in my stats is how I would expect to see it BUT the speedtests that I've done on ThinkBroadBand, BT Perf Test and others all return about 22Mbps download. Until the day before yesterday it was consistenly 44Mbps (I'm on 55/10). I suffered a 20Mbps loss of measured download speed overnight.
It's almost as if I'm stuck on a failing gateway but my old habit of gateway hopping isn't working and I don't understand why my IP isn't changing after what must now be a couple of dozen re-connects.
Fixes: 334
@longedge t's almost as if I'm stuck on a failing gateway but my old habit of gateway hopping isn't working and I don't understand why my IP isn't changing after what must now be a couple of dozen re-connects.
Those 'couple of dozen disconnects/reconnects' over a relatively short period of time will be the reason you've lost speed - the DLM will have read this as an unstable line and attempted to stabilise it by reducing the speed and increasing the signal-to-noise ratio.
Because of the way IPs are 'localised' for Plusnet connections, it is possible to get the same one back regularly unless you stay disconnected for a longish time, especially if the local 'pool' you are on is fairly small, and other users are not changing, so not releasing a different one.
longedge
Fixes: 4
My understanding of DLM is that it is repeated loss of sync that causes problems. Am I wrong? Does dropping the ppoe session and re-connecting trigger DLM intervention? I have actually re-booted my router i.e. lost sync as well a couple of times but that only since the drop in speed. The SNR I am seeing is exactly the same as it has been for weeks now, is that not a measure of whether DLM intervention has occurred?
If I lose sync then a re-connection takes approx 7 minutes. If I force a new session it takes between 1 and 2 seconds. In the past, more often than not a new session meant a change of IP but this has changed recently.
Fixes: 334
You could well be correct in your first paragraph, @longedge , but I don't know if that is correct for an FTTC connection - hopefully @Mustrum will come back and enlighten me - I admit my VDSL knowledge is at a fairly low level, but I am learning.
I can't comment on reconnection speeds - I had an almost 12 month uninterrupted connection with Plusnet and have lost it only once with my current supplier - and that was initiated by them to allow a router firmware upgrade, do will be ignored anyway.
As I say, if the pool of IPs yours is allocated from is fairly small , only a long loss of sync is likely to trigger a change of IP - out of curiosity, why would you want a new IP?
DLM certainly will have raised your SNR - to correct a fault, so maybe a deeper examination is required.
Am I correct in thinking this is a Fritz!box router? What is your current uptime?
longedge
Fixes: 4
"why would you want a new IP?"
😃 TBH I don't particularly. I used to have one years ago but didn't need it so gave it up. It's just that I see the 'sticky' IP as something that has changed recently and wonder if it is an indicator to some people of where the problem might lie.
p.s. - Yes it's a Fritz!bOX 7530 and my current uptime is just a few hours. Previously it was around 14 days. Forcing a new ppoe session doesn't affect the sync uptime.
Mustrum
Fixes: 81
If you were to run the advanced BTW speed test then we/you would see if it is congestion, rather than DLM that was slowing you down.  DLM would also slow the sync speed, which has not changed.
It has been a while since I was a customer and did the gateway hoping trick, but like getting a new IP, since the new sticky network was implemented a longer line break, even overnight can be needed.
Fixes: 334
@Mustrum The 'attainable' throughput is somewhat higher than the 'current' - is that indicative of a problem? I withdraw my comment re: the SNR, as it may be a red herring - it is the same as mine, and I am running at near max speed on speed tests.
longedge
Fixes: 4
BTW advanced test failed several times earlier on today with a message saying it couldn't proceed. I'll try it again now.
edit - still the same.
Summary of Performance Test
Timestamp
Wednesday 1 September 2021 | 21:47:4
Ping
22 Ms
Download
22.69 Mbps
Upload
8.49 Mbps
Summary Advanced Test
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
Mustrum
Fixes: 81
@jab1  no, that is normal, although the difference to the actual sync speed may indicate a bit of banding.
But the lower speed test suggest congestion, either in the home or maybe exchange, but it would not be consistent..
No much detail shared so far, so will see what else is forthcoming.
longedge
Fixes: 4
OK, well I'll give it a rest for now. At least the connection is still useable. If it's the same tomorrow morning I'll switch the router off for 3 or 4 hours and see if that makes a difference.
As far as congestion goes, I live alone and there's nothing running that hasn't been doing so for a year or two now.
p.s. I'm sure that my connection is banded (as I understand it), the estimated line length in my stats 735 metres is correct within a metre or two. The long re-sync times I see are down to the fact that my cabinet has vectoring, according to one of the engineers I had in a while back.
Fixes: 334
@longedge I attempted the advanced test on my (Zen) connection and got the same response on it - methinks it is broke.
Out of interest what do you get on (say) the Thinkbroardband test?
longedge
Fixes: 4
Just tried - 22.6Mbps / 7.3Mbps interestingly the upload is pretty much normal.
longedge
Fixes: 4
Service dropped around 01:30 hours and everything back to normal now.
