DNS to block adverts on Sony Smart
andrewsimpson70
Is there a way to change the DNS server settings on the plusnet hub one ?
2 REPLIES 2
Fixes: 122
Re: DNS to block adverts on Sony Smart
@andrewsimpson70
there is no option on the Hub One to make this change.
You need to use a 3rd party modem/router.
Dan.
Fixes: 524
@andrewsimpson70. but you could probably set the DNS on the device (TV?).itself https://www.sony.co.uk/electronics/support/articles/00125843
Use an ip address out of the router dhcp range, assuning the router is set to defaults, use something between 192.168.1.1:and 192.168.1.63
