Constant packet loss since 25/4/22
RobPN
Fixes: 13
As subject - since approximately 2:00 pm on 25/4/22 I've been seeing packet loss 24/7 on my FTTP (trial) connection.
Not a major problem but something seems to need looking at to eliminate this new 'feature' on my TBB BQM graphs.
Neither graph below includes any heavy downloading which sometimes does result in some packet loss; present activity is just background stuff, including many browser tabs open, but that doesn't normally result in packet loss.
I'm on a static IP if that's relevant (which I wish to keep).
First image below is todays, showing said packet loss, below that is what it normally looks like.
I can provide the live BQM link by PM if required.
EDIT: My router has been rebooted a few times and I've even rebooted the ONT
10 REPLIES 10
RobPN
Fixes: 13
Re: Constant packet loss since 25/4/22
It's probably not a coincidence that following my post above, after 8 days of constant packet loss it has now stopped.  I presume someone from the PN team intervened, so a big "thank you" to whoever that was.
This morning at about 7:30 my Internet wasn't connected so I assumed something was being done, and although the lights on the ONT looked normal I decided to reboot it.  After a few minutes I realised whatever had been done had confused my router which normally reconnects automatically, so after rebooting it all was well.
It'd be interesting to know what the problem was.
I hope I'm not speaking too soon, but here's a screenshot of todays BQM graph showing no packet loss since reconnecting.
I'm not sure what the activity is between 20:00 and 22:00 which seems to be a fairly regular occurrence recently.  I don't think it's caused by usage on my connection, so perhaps contention kicking in due to a heavy user on the same splitter as me, or a hot VLAN?  I'll watch out for that disappearing now the dropped packets issue has been fixed.
Edit: typo
RealAleMadrid
Fixes: 68
@RobPN  Very unlikely that Plusnet had anything to do with the change you have seen. They have hardly any diagnostic information for FTTP services. Openreach had probably detected a network problem and done something to fix it. Hope it's OK now and the congestion you have seen goes away.😁
RobPN
Fixes: 13
@RealAleMadrid
Thanks. Thumbs_Up
I didn't make it clear, but my reference to someone from PN intervening was intended as someone from PN reporting the problem to Openreach, which of course us mere mortals can't do! Wink
Fixes: 1,653
Did someone say Gandalf? But seriously I put my shoes on one at a time just like everybody else. Smiley
As you can see from the 'in-depth' testing I've attached below (:D), the tests aren't showing any issues and they'd generally only show an issue if something was completely broken.
GEA Test Detail
Circuit ID NA Service ID [redacted BBEU]
Test Outcome Pass
Test Outcome Code GTC_FTTP_SERVICE_0000
Description Service is OK in the Openreach network. Please check the customer home environment set up.
Main Fault Location OK
Sync Status Up
Appointment Required N
Fault Report Advised N
DP Type External
RRT Report Summary
Confirmed FRC from RRT TOK
Parameters MIN MAX AVG
Transmitted Traffic 0.0 Mbps 4.8 Mbps 0.0 Mbps
Received Traffic 0.0 Mbps 73.7 Mbps 0.3 Mbps
Downstream Policing Discards 0.00 0.00 0.00
Upstream Policing Discards 0.00 0.00 0.00
Also the S-VLAN is showing as green with no congestion seen, so seems to rule that out.
I'd recommend keeping an eye on it and if you get issues again, it may be worth calling out the true immortals (Openreach). At this stage if I were to report the fault to Openreach, we'd need to arrange an engineer visit.
Fixes: 105
@RobPN
I seem to recall from a post a while back that @Gandalf stated it took a few days for posts on this Forum to feed through to support. You need someone like him or @bobpullen  to have a look. They at least know something about the FTTP Trial.
Edit : Sod's law - Gandalf posted while I was typing.
Fixes: 1,653
Jono fixed that issue and the posts now feed through a lot quicker! Smiley
RobPN
Fixes: 13
All seems to be sorted now thanks @bmc (see my post #2 above) Thumbs_Up
RobPN
Fixes: 13
GEA Test Detail
Test Outcome Pass
Sync Status Up
DP Type External
RRT Report Summary
Thanks @Gandalf
I appreciate my connection wasn't completely broken, but is there anything by way of test results or logs to distinguish any differences in the status of my connection before and after approximately 7:15 this morning when the BQM graph in post #2 shows my connection was interrupted?
Fixes: 1,653
The most I can get for you is our RADIUS logs below, because there's no RRT data for FTTP as there's no DLM.
RobPN
Fixes: 13
Thanks @Gandalf
The number of connection drops is probably nothing to do with the service but more than likely down to my ageing DrayTek router which seems to reboot for no apparent reason, although there are a lot of browser tabs open so maybe it doesn't like the number of sessions.
