Constant issue for years
Croger
Re: Constant issue for years
its something that happens at random, i could go a week with no drops but then another week where it drops every day or up to dropping 4 times a day, its not a fixed thing that happens at same time every day so right now no it hasnt dropped in last day or 2 since post but will it drop again? yes i can say with 100% that it will happen again like it has since iv had plusnet, its a on going issue that im 100% sure is the leading up to house since engineer had checked everything inside house already and it still happens.
Fixes: 1,662
Thanks for getting back to us @Croger
I'm sorry to see you've been having issues with your connection.
From what I can see we haven't arranged an engineer in over 2 years, so I think it'd be worth arranging another visit to take a closer look though it may be best waiting until the problem happens again, as it's unlikely they'll find an issue while your connection's stable and your line's testing OK.
I've attached below a copy of our testing if it helps and also a graph showing your connection over the last 30 days:
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 40.0 Mbps
Upstream Speed 10.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Cross Talk Not Detected
Estimated Line Length In Metres 735.4
Upstream Rate Assessment Very Good
Interference Pattern Regular Interference Observed Daily
Service Impact Retrains Observed
Interference Duration Longest Occurrence From03:45to04:00
Interference Location Unknown
Interference Observed In Days 0
Technology VDSL
Current 15Min Bin Retrains 0
Last 15Min Bin Retrains 0
DP Type External
Profile Name 0.128M-40M Downstream, Retransmission Low - 0.128M-10M Upstream, Error Protection Off
Time Stamp 2021-12-01T11:45:00
Parameters MIN MAX AVG
Down Stream Line Rate 39.9 Mbps 40.0 Mbps 39.9 Mbps
Up Stream Line Rate 9.5 Mbps 9.9 Mbps 9.9 Mbps
Up Time 270.0 Sec 900.0 Sec 897.1 Sec
Retrains 0.0 8.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2021-12-14T11:12:30Z 2021-12-14T11:27:30Z
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
