Connection speed down to 33% of normal
kmw350
I just noticed that my (Full Fibre 145) internet down speed is about 47Mbps when it is normally 150Mbps.
(BTW, this is a wired connection to my pc, not wireless)
Can anyone please advise me what I should do?
3 REPLIES 3
Fixes: 463
Re: Connection speed down to 33% of normal
Moderator's note:
Thread moved from Broadband to Full Fibre
Fixes: 463
@kmw350
Report a problem using the mobile bot, see:
https://www.plus.net/help/report-a-problem/
kmw350
Thank you @baldrick will do (sorry I posted in the wrong section!)
