Connection constantly drops when it is windy and raining
Tandleman
Re: Connection constantly drops when it is windy and raining
It has just staerted raining and connection immediately dropped.
Peter
MatthewWheeler
Fixes: 503
Thanks for getting back to us @Tandleman.
I'm sorry to hear that your connection is having issues again.
So we can investigate further can you raise a fault here and post back once you've done so.
This will allow us to pick the matter up straight away
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
mojacarkev
They will tell you to raise a fault then tell you an engineer is booked but if he finds no fault they charge u £65 they will never find an intermittent fault. And if fault occurs when they are on site they use excuse their equipment knocked it out for a second. Most of the times it's the [-Censored-] wiring from pole to house but you can guarantee the fault will be inside according to them.
Tandleman
Ticket now raised. It certainly isn't in the house as it rarely rains in here! (-:
adamwalker
Fixes: 223
Cheers, I've just reported the fault with our suppliers and have added an update to your account here: https://www.plus.net/wizard/?p=view_question&id=189617709
 Adam Walker
