Can't access Router homepage?
cjwinternet
ten minutes ago I accessed my routers homepage to reboot it.
Now I can't access it, it says "Access to the hub manager now requires a secure HTTPS connection  - Switch to HTTPS (button)
Click the button, nothing happens.
14 REPLIES 14
pvmb
Champion
Fixes: 17
Re: Can't access Router homepage?
"Now I can't access it, it says "Access to the hub manager now requires a secure HTTPS connection  - Switch to HTTPS"
Yes you can access it. Just continue as browser describes: Hub Warning (plus.net)
cjwinternet
Are you a little bit simple? First, that's not even the same message.  Second, which part of "Click the button, nothing happens" did you not understand Huh
Fixes: 585
@cjwinternet
can you access the router if you use https://192.168.1.254/ directly ( and accept the certificate security warning )
cjwinternet
It's got nothing to do with the security warning.  It's literally the image that I attached again below.
Edit, I fixed it
Fixes: 585
I understand that, I was suspecting that the browser wasnt handling the router generated force switch url and so suggested entering the https: url directly to eliminate the force switch link as the problem
pvmb
Champion
Fixes: 17
Err...
Which is exactly the matter addressed! 🤣
Edit, I fixed it
Good! What was the fix? It might be useful to know.
cjwinternet
"Which is exactly the matter addressed! :rolling_on_the_floor_laughing:"
No, you tried to address what would happen in the NEXT screen, when you change protocol.  It's only then that you would ever get the certificate security warning.
And no, I won't tell you what I did to fix it.
pvmb
Champion
Fixes: 17
"And no, I won't tell you what I did to fix it."
Oh. That's helpful, then... 🙄
cjwinternet
Neither was this... "Which is exactly the matter addressed! :rolling_on_the_floor_laughing:"
hikernick
I have this problem too - only since some time this afternoon. Plusnet fibre installed yesterday, spent all afternoon configuring devices, ip addresses etc. Went to do some more today, now I get blocked entirely by Edge on Windows (ERR_NETWORK_ACCESS_DENIED). On Android I get the "switch to https" screen, but the button is not a button. You click on it, and a cursor appears as if you clicked in some plain text. Rather irritating. So if you could share your fix, that would be great.
pvmb
Champion
Fixes: 17
@cjwinternet @hikernick
"I have this problem too - So if you could share your fix, that would be great."
hikernick
I powered the router down and back up. Then I was able to access it for a little while. Then it hung updating a device icon, and since then it says "took too long to respond" in the browser. Guess the web server is somewhat flaky. When I have some down time I'll reboot it - again...
Craig5274
Thank you for being so willing to help others new to this community. As they say with friends like you .....
cjwinternet
Awwwww bless
